  • 4 weeks later...
Wow! It's been so long between visits I just stumbled across this thread.
Many belated thanks peeps. Had a fun combined birthday party in Macau with another mate. Copious amount of partying but had to be kerbed to a point coz we were playing a big poker tourney the next day.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
