I've heard from an unfortunately reliable source (father, old skool mechanic) that the fuel overflow runs back into the catalytic converter, so if you fill your tank too high consistantly, it will ruin your cat. Can anyone confirm this at all?
Just wondering, coz currently I do this *gulp* lol as it's the only way I can accurately record fuel consumption per tank.
https://www.sau.com.au/forums/topic/285549-fuel-overflow/
Catalytic convertor definately not, charcoal canister possibly, used to happen to mid 80's Fords alot. Don't worry about it.
https://www.sau.com.au/forums/topic/285549-fuel-overflow/#findComment-4794876
In brief overfilling causes Fumes in the car and Fuel spills on the ground. It can/will damage the charcoal cannister.
Overfilling the tank will be the cause of fuel vapors. A small dome at the top of the fuel tank normally is reserved for air and allows for the expansion of the fuel in the tank. If this domed area is filled with fuel, liquid gasoline can enter the evaporative emissions system when the fuel in the tank expands. Components in the evaporative emissions system, like the charcoal canister, can be damaged from liquid gasoline. While it’s okay to round your fuel purchase to the nearest even amount after the pump handle clicks, it’s not a good idea to continue pumping until gasoline runs out of the filler neck.
and if your doing fuel consumption sums based on overfilling your tank your getting incorrect data as it would be more than your fuel tanks size (60L or 70L tank).
https://www.sau.com.au/forums/topic/285549-fuel-overflow/#findComment-4794931
The problem with filling my tank up, is that there is no way to do it to the normal amount - being when it cuts out. Just about no matter what position I hold the nozzle in, it cuts out immediately.
By filling it to the same point each time, I know how many litres of fuel it took me to get the distance my trip meter is reading.
The only reason I filled it to the "top" (I stop before it actually overflows lol) is so I know how much fuel I used, if there wasn't something retarded about my fuel tank and not letting me fill it with the nozzle in all the way, I'd be able to fill it til it stopped like it should.
This raises a new question - what the shit is wrong with my tank stopping me from putting the nozzle in? :)
https://www.sau.com.au/forums/topic/285549-fuel-overflow/#findComment-4795109
Who ever complied your car did a sh!t job on the filler neck maybe.
When they comply Skylines they have to replace the filler and filler cap area with an ADR approved unit. Sometimes they don't fit it up properly, you get leaks at the join, and a bad join that is not smooth or has been restricted. No saying this is your problem, but worth looking at.
https://www.sau.com.au/forums/topic/285549-fuel-overflow/#findComment-4795582
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
