  • Replies 188
Posted Images
so over the weekend tried to see if I could build a new intake. try and route it down by radiator and put a pod near wheel arch.
got some measurements but decided for now I'll get rid of the AFM and put a straight through pipe in.
seems to have worked a treat.
not with the pipe fitted and reworked the original bracket, the intake seems very flush and doesnt move one bit. Finally!
oh, and the AFM seems quite restrictive..!
now for those smart techy people, is it worth putting it back on the dyno to see if all ok? Im not exopecting any gains I guess just to see if all good.
  • 1 month later...
  • 1 month later...
Finally an update...
MRA Round 2.
qualifying was tough, we had 23 cars on the track. 15 MX5s and 8 Excels.
couldnt get into space and managed a 1.13.2 putting me 11 out of 15 on the Mx5 grid.
race 1 got a great start. made a couple spots up the field however last lap I tried too hard and came off and spun at turn 4, did a 360, car stopped and stalled and wouldnt restart. My first DNF this year.
that put me to starting last on the MX5 grid (we had a shared race with the excels)
made a few moves, got ahead of some others, last lap chasing the bloke from race 1 and I manage a PB with a 1.12.3
not bad for 82rwkw!!
last race was the trophy race. the whole race was an epic battle as you'll see in the vid below.
enbded up 3rd in 2F class again which was great.
my PB lap
race 3 highlights
Next event is FoSC 1st June.
  • 4 weeks later...
not much of an update, havent touched the car since last MRA round.
did Festival of Sporting Cars today at SMP soouth. was in the race class 'historic and invited sports cars'
qualified 5th out of 21 with a 1.05.68 and race 1 ended up 3rd with a 1.05.67!
now the interesting part. I came 3rd but did the 7th fastest lap. So in this meet I started 7th based on lap time. weird. Anyhoo, race 2 came 5th and thats when the rain started to hit.
last race was a handicap race. So if you were slow, you had a better starting place on the track. We all started at same time but everyone was at different starting points. Ended up catching and overtaking quite a number of cars in the rain. Turns out I came 1st! won the last race!
vids to come.
one thing about FoSC which I think is fantastic is the lunch time partners parade.
As my Dad was out there watching and supporting me, I couldnt think of anything better for him than to throw him the keys. He ABSOLUTELY loved it! might see him and his NA6 out at the track soon now, think I got him hooked!!!
on the dummy grid for last race
not the clearest photo
race 1 mazda dominate!
me in 3rd.
http://racing.natsoft.com.au/635483948/object_12206240.91W/View?7
  • 5 weeks later...
hahaha
yeah slight flesh wound. first racing incident in 4 years.
but thats racing mate!
Was still happy with my efforts at the start of the day.
qualified 20th out of 27 in TT and then came 13th race 1.
MX5 qualified 3rd overall out of 8, but came 4th race 1 and then went down hill there. slave cylinder issues causing me to miss gears in TT race 2.
trophy race TT came 3rd in under 2L and then trophy race MX5 at turn 5 copped a wack rear RHS and got spun off.
didnt want to risk it so came in to pits for DNF
  • 4 weeks later...
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
