  • Replies 188
Posted Images
so over the weekend tried to see if I could build a new intake. try and route it down by radiator and put a pod near wheel arch.
got some measurements but decided for now I'll get rid of the AFM and put a straight through pipe in.
seems to have worked a treat.
not with the pipe fitted and reworked the original bracket, the intake seems very flush and doesnt move one bit. Finally!
oh, and the AFM seems quite restrictive..!
now for those smart techy people, is it worth putting it back on the dyno to see if all ok? Im not exopecting any gains I guess just to see if all good.
  • 1 month later...
  • 1 month later...
Finally an update...
MRA Round 2.
qualifying was tough, we had 23 cars on the track. 15 MX5s and 8 Excels.
couldnt get into space and managed a 1.13.2 putting me 11 out of 15 on the Mx5 grid.
race 1 got a great start. made a couple spots up the field however last lap I tried too hard and came off and spun at turn 4, did a 360, car stopped and stalled and wouldnt restart. My first DNF this year.
that put me to starting last on the MX5 grid (we had a shared race with the excels)
made a few moves, got ahead of some others, last lap chasing the bloke from race 1 and I manage a PB with a 1.12.3
not bad for 82rwkw!!
last race was the trophy race. the whole race was an epic battle as you'll see in the vid below.
enbded up 3rd in 2F class again which was great.
my PB lap
race 3 highlights
Next event is FoSC 1st June.
  • 4 weeks later...
not much of an update, havent touched the car since last MRA round.
did Festival of Sporting Cars today at SMP soouth. was in the race class 'historic and invited sports cars'
qualified 5th out of 21 with a 1.05.68 and race 1 ended up 3rd with a 1.05.67!
now the interesting part. I came 3rd but did the 7th fastest lap. So in this meet I started 7th based on lap time. weird. Anyhoo, race 2 came 5th and thats when the rain started to hit.
last race was a handicap race. So if you were slow, you had a better starting place on the track. We all started at same time but everyone was at different starting points. Ended up catching and overtaking quite a number of cars in the rain. Turns out I came 1st! won the last race!
vids to come.
one thing about FoSC which I think is fantastic is the lunch time partners parade.
As my Dad was out there watching and supporting me, I couldnt think of anything better for him than to throw him the keys. He ABSOLUTELY loved it! might see him and his NA6 out at the track soon now, think I got him hooked!!!
on the dummy grid for last race
not the clearest photo
race 1 mazda dominate!
me in 3rd.
http://racing.natsoft.com.au/635483948/object_12206240.91W/View?7
  • 5 weeks later...
hahaha
yeah slight flesh wound. first racing incident in 4 years.
but thats racing mate!
Was still happy with my efforts at the start of the day.
qualified 20th out of 27 in TT and then came 13th race 1.
MX5 qualified 3rd overall out of 8, but came 4th race 1 and then went down hill there. slave cylinder issues causing me to miss gears in TT race 2.
trophy race TT came 3rd in under 2L and then trophy race MX5 at turn 5 copped a wack rear RHS and got spun off.
didnt want to risk it so came in to pits for DNF
  • 4 weeks later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
