  • Replies 650
ill meet you guys at lala, much closer to my house than vilis :thumbsup:
cant wait. might need a hand fitting an oil cooler this weekend.
Pussy, I'm leaving Golden Grove extra early to make it, I think you can too :(
ill meet you guys at lala, much closer to my house than vilis :P
and ill be going craigmore -> golden grove -> vili's -> mallala.
Im close to pulling out, dont know if the car will be ready on time. If not much changes a week prior to track day than I'm happy to let someone else in to my spot.
I'll take it, I've been rebuilding my 32 gtr track car for a year after a number of blow ups first at Mallala and then a N1 pump let go at collingrove on it second run. "I need some track time"
cant wait myself... :)
20% larger injectors drop in on thurs, along with the f/ic-8 ecu. tune day :whistling:
hoping the stagea feels good. does so far with the wider track rims and wheel align.
brakes will be the downer :D
I am still keen. Found a few problems with the race R33 yesterday at Time attack (brake bias, full pressure etc)
so hoping to have it more sorted for 26th. Need lots of practice with this new set up so looking forward to it.
John, seeing the 33 on the track yesterday was awesome! How many litres of fuel do you use per lap?? The amount of exhaust coming out the side is beyond comprehension!! :/
And Chad - as much as I love your 32 it'd be good to see the Stag out there (minus trailer of course :)), more family spec wagons the better!
Ah, I am not sure at this stage. We are running the car pretty rich until all sorted out.
Is great fun to drive (as you can see I was all over the track) so will have to train the beast
& try to knuckle down & get it consistent.
I am trying to learn the track at the same time as learning to drive the car so have a long
way to go. My main goal is having fun, & not wrecking the car so my first mission out there
was successful. Had a ball & car is in one piece.
There will be no point tuning the car for more power until I can drive it properly so will keep
going for it till then & when James feels I am ready we will put slicks on it & turn up the wick!
This engine is capable of some serious power & the car is very tight & quite light so when the
time is right I will certainly not be weak.
Hoping they open AIR for circuit racing again one day, because I would love a go at the straight
with a run up off the bowl............ now that would be fun.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
