  • Replies 650
ill meet you guys at lala, much closer to my house than vilis :thumbsup:
cant wait. might need a hand fitting an oil cooler this weekend.
Pussy, I'm leaving Golden Grove extra early to make it, I think you can too :(
ill meet you guys at lala, much closer to my house than vilis :P
and ill be going craigmore -> golden grove -> vili's -> mallala.
Im close to pulling out, dont know if the car will be ready on time. If not much changes a week prior to track day than I'm happy to let someone else in to my spot.
I'll take it, I've been rebuilding my 32 gtr track car for a year after a number of blow ups first at Mallala and then a N1 pump let go at collingrove on it second run. "I need some track time"
cant wait myself... :)
20% larger injectors drop in on thurs, along with the f/ic-8 ecu. tune day :whistling:
hoping the stagea feels good. does so far with the wider track rims and wheel align.
brakes will be the downer :D
I am still keen. Found a few problems with the race R33 yesterday at Time attack (brake bias, full pressure etc)
so hoping to have it more sorted for 26th. Need lots of practice with this new set up so looking forward to it.
John, seeing the 33 on the track yesterday was awesome! How many litres of fuel do you use per lap?? The amount of exhaust coming out the side is beyond comprehension!! :/
And Chad - as much as I love your 32 it'd be good to see the Stag out there (minus trailer of course :)), more family spec wagons the better!
Ah, I am not sure at this stage. We are running the car pretty rich until all sorted out.
Is great fun to drive (as you can see I was all over the track) so will have to train the beast
& try to knuckle down & get it consistent.
I am trying to learn the track at the same time as learning to drive the car so have a long
way to go. My main goal is having fun, & not wrecking the car so my first mission out there
was successful. Had a ball & car is in one piece.
There will be no point tuning the car for more power until I can drive it properly so will keep
going for it till then & when James feels I am ready we will put slicks on it & turn up the wick!
This engine is capable of some serious power & the car is very tight & quite light so when the
time is right I will certainly not be weak.
Hoping they open AIR for circuit racing again one day, because I would love a go at the straight
with a run up off the bowl............ now that would be fun.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
