  • Replies 650
Ah, I am not sure at this stage. We are running the car pretty rich until all sorted out.
Is great fun to drive (as you can see I was all over the track) so will have to train the beast
& try to knuckle down & get it consistent.
I am trying to learn the track at the same time as learning to drive the car so have a long
way to go. My main goal is having fun, & not wrecking the car so my first mission out there
was successful. Had a ball & car is in one piece.
There will be no point tuning the car for more power until I can drive it properly so will keep
going for it till then & when James feels I am ready we will put slicks on it & turn up the wick!
This engine is capable of some serious power & the car is very tight & quite light so when the
time is right I will certainly not be weak.
Hoping they open AIR for circuit racing again one day, because I would love a go at the straight
with a run up off the bowl............ now that would be fun.
It's not running rich...and the wick is up there...about 900hp worth on time attack day. I think you will go faster with less boost to be honest as we saw on the data logging.. Anyway I'll see you at the shop. =)
How did we go from having 3 reserves to having 2 spots free? Did 5 people drop out?
I posted on the Aussiefrogs forum and on Facebook as well as sent a message to a friend of mine who has a Porsche Boxter and competed at the Philcom time attack recently. I'll let you know if I get any bites but it is short notice.
whats it running on? hopes and dreams?
eta til its back up and running dale?
It was supposed to be just before extreme HP show, but Study has got in the way of that so it'll be up and running before teh end of November (touchwood). It'll be going straight on the market once it's back together but should be making another 20kw as well as the 264HKS cams are going in.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
