im from liverpool and i already know 2 other r32's coming...i met one of you guys at mcdonalds today and the other guy was the guy who helped me with my turbo conversion...meet at prestons maccas and we can cruise together?
id be up for this, what time you guys thinkin of meeting???
  • Replies 328
Do we have to pay first before we eat?
Never knew.
PM details please.
RJ
The $20 is to reserve a seat. By the looks of things you get the deposit back by occupying a seat on the day. I'm sure Druncan can confirm this :D
meet at oportos casula on hume highway/camden valley way at 9:30am
so you guys definite on meeting there , i posted a meet at hungry jacks in warwick farm but if casula oportos is better we can meet there
i can update that post then so meetup is changed to oportos casula is everyone is definite
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
