Gents.
One of my rear wheels (thats right, only one) is scrubbing on the guard when i've got people in the back seat.
I figure that it doesnt happen on the other side because it must have very slightly more negative camber.
Is it possible to adjust the rear camber at home, and if so, any tips?
Thanks in advance.
And before you suggest I head out to get a wheel alignment, im just after a quick temporary fix. Wheel alignment is coming soon along with new tyres.
https://www.sau.com.au/forums/topic/286428-how-to-adjust-rear-camber/
don't do it at home... just stop putting people in the back, put them on the good side!
Check tyre pressures...
Think laterally. Is it really the camber, maybe it is a soft shock, shorter spring, the camber of the road, the weight of the people in the back and is it really the tyre and not some other noise.
Thanks Stephen.
It doesnt matter which side the people sit in. A "large" passenger in the front seat has the same effect.
Tyre pressures are OK.
Springs are the same on both side (aftermarket RSR Ti2000). Shocks are nismo s-tune. Both appear fine.
The scraping doesnt occur when I run the standard 18s. These 20"s are in a much more agressive offset.
The RHS appears that it could JUST BARELY tuck under the guard over bumps, where as the LHS looks like there is no chance. This is why I think I can dial in a tiny bit more neg camber on the LHS and it will be OK.
fender rolling is the only wat. what is your size on you wheels? the width play effect too. mine is 10.5 rear with 22+ offset and 275 tyre scrub with passenger as well. fix the scrubbing by fender rolling.
Perhaps your diff and rear axle (bushes) are kicked to one side slightly.
Should be absolutely central unless it has taken a knock. Would still suggest that you take it to a professional. Maybe you could take some measurements first and see how much it is.
Use some straight edges on the face of the wheel and see where the guard sits...
Seems very odd, unless something is installed incorrectly.
If there is 'No Chance' that the wheel will clear on the left, I would have thought you will not get enough adjustment by just negative camber adjustment. Not sure you can use much more than 1 degree negative and it is a dangerous not doing it correctly.
Pick up a copy of High Performance Imports Issue 110 (High Performance) and take a look in the handling pages.
The maximum -camber is not a large figure
Thanks.
Rears are 20x9.5 +22, wearing 275/30.
There is JUST enough room to get away with not rolling the guards. However, my plan is to eventually get it done once I fork out for some better rubber (and run less agressive camber).
Stephen, thanks again for the additional ideas.
I dont want to sound stubborn but it really is a camber issue.
I tried to take a photo of the underside of the guard but my photographing skills are sub-par. Once you see the black mark left by the tyre and how close it is to fitting underneath, it will make a lot more sense.
I dont have a protractor (ha ha) but it looks like even 0.5 of a degree may be all it will take.
In any case, with some help I discovered how to adjust the camber but we could not get enough leverage on the bolt. Will get it done tomorrow and report back.
I'm running 20 x 10.5 + 22 w/- 285's on the rear. Ive got stock camber, had the guards rolled slightly and no rubbing. There is no camber adjustment without going aftermarket and I can't see that being your problem. You must have a rear end alignment problem. Might be worth taking to a pro who can diagnose the issue and possibly fix it.
Edited by mosoto
I was going to ask if it was the left side rubbing when you take right hand turns, as the turn you take is a bigger arc, higher speed, weight shifts over a bit more..
... but I guess not.
I agree completely, especially with the idea that there is "no camber adjustment without going aftermarket".
Unless you have something different, most Nissan's do not have Camber adjustment as standard... I'll stand corrected but that is front or rear from my knowledge.
They do actually but only to a very minimal degree. I had a wheel allignment done on my 35 months ago and rear cambers were corrected slightly. I Also remember my R34 had a little bit of camber correction done as well. It is very marginal but there is a small degree in there. Failing which most people get camber kits. I would not recommend you play with those adjustments but rather get it to a wheel allignment specialist.
Easy fix would be to roll the inner lip.
I personal gripe of mine is when people post incorrect info on public forums.
Camber IS adjustable on the rears from factory (via the eccentric bolt on the camber arms). The scope of adjustment is minimal but it is there. Toe can also be adjusted via the toe arm.
The fronts are another story.
Thread can be closed, my problem is solved. Thanks for listening.
How did you solve your problem?
The info was correct sir. The camber bolt is a very marginal adjustment and has no effect on any suspension arm angle other than stock. There certainly would not be enough adjustment on a lowered vehicle.
when you say "not enough adjustment" for a lowered vehicle, how many degrees / minutes can the stock camber bolt change camber?? +/-
Most cars I know of dont really have excessive camber changes even when slammed...usually aftermarket options are a last resort to actually dial more negative camber than what the factory bolt will allow.
The info was correct sir. The eccentric camber bolt has a very marginal adjustment and does not have enough "range" in order to return camber to stock with a lowered suspension.
edited to be more specific.
I was able to get the morning off work.
Stopped by the tyre factory. Surprise surprise, camber on the LHS was -0.5 something, RHS was -1.4 something.
A quick adjustment and the problem was FIXED. -1.5 or there abouts on both sides now and no scrubbing.
Cool, that was exactly what mine was corrected to -1.5 after I lowered it on 350z suspension.
The lower you go the more natural camber you will have.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
