Hi guys, not sure where to put this as I'm not selling anything personally but just seeing who might be interested in an aftermarket airbox/heatshield.
I'm getting one made up for myself locally out of stainless steel but thought some of you might be interested in this too so ill give you a run down of what I'm getting and if anyone is interested I can pass the details on to you...
Basically its laser cut and made to sit in the passenger side corner behind the headlight, its got an opening through the side for the afm to attach to and have a pod on the inside as well as a cut out to clear the hot pipe for the inter cooler.
I haven't got pics of it installed but I do have some 3d renderings which ill photoshop inside the engine bay later to give you a better idea.
Price is around $130 for basic stainless steel airbox in either polished finish or powdercoated in a basic colour (black,white,red,blue etc)
However, for a bit extra you can have custom metal finish (zinc, blue gold, chrome etc) or custom powdercoated colour as well as custom engraving or cut outs on the lid. pretty much anything can be done such as a forum user name, number plate, jap brand name etc... (all laser cut)
I havent got exact pricing for all the extras but I can inquire about it if anyone wants it.
If enough people are interested ill set up a group buy.
Thanks :D
- Marko
Edited by SkyHi_33
https://www.sau.com.au/forums/topic/286501-interest-for-aftermarket-airboxes/
f**k man, thats damn cheap. if its available for the s14 id be keen.
I'll ask, they will need a base car to take measurements etc for tho but if there's enough interest i don't see why not.
Another thing I forgot to mention is that the airbox is all press bent so its basically a perfect finish and should bolt up to stock mounting points around that area.
hell, they can use my car as the test run...
... if i can lowball myself a discount. :D
(actually, with the s14 one, could probably start marketing it on ns, s14 and s15 = same)
Edited by scandyflick
I'm making some out of Carbon fiber for RB25DET R34 . If you make them out SS will absorb heat too much !!! actually bet the temps will be higher then the lack of airbox ? unless its aluminum ???
My designs have a top that can be removed for the defect police and the second generation will be two carbon fiber snorkles into a KN style filter a hi volume factory box completely sealed off from below as well and include heat shield option on the back side.
should have mine done for the car show in loxton, dual snorkles
This carbon one sounds even more advertising... How muchies approx?
Im not selling them yet..lol but If I did around 300 for option 1, option 2 400ish
can make some for other models with a donor car for exact molds to AFM, connection points
will be using aircraft type fasteners , half turn to remove , quick release similar to below
Im sure that the Clark rubber heat resistant adhesive foam would counteract the head absorption by not letting the heat affect the air going into the pod. I dont think it is that expensive either, need to get some for my airbox.
Definantely like the look of this set up, but I agree the material is probably wrong.
They look like a pretty smart setup, would like to use them on a whole heap of spots that the crappy plastic ones are. Do they make a version of these for thin panels? It looks like those need something fairly thick to lock into.
I got mine from just jap, had to make a few mods for my pod setup but it does the job.
http://justjap.com/store/product.php?produ...at=0&page=1
The also make them in carbon.
these are made for aircraft aluminum skins , so they come in all sorts of sizes, I just grabbed the first example for photo purposes
they only take a half turn to remove them, also come in straight slot screws for use with 5 cent coins , roadside removal ??
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
