Survey: Ecu Reflash/tune In Australia
Engine Tuning in Australia
56 members have voted
It looks like there is room to fit a traditional wastegate with a basic screamer to perform a test. You just don't see people using these straight gates on mass still.
What is shown here by GTs is what I was getting at about the gate being non linear. It's like the throttle in your car. Roughly 80% of your power is controlled with 20% of the throttle blade movement. Same same for your wastegate which makes control very hard.
Not in front of a computer until later tonight so this is probably the best I can do for now. We are using both ports on the wastegate eith the 3 port Mac valve, I've just changed it to single in the photo as I was trying it out on gate pressure
Or just wire a multimeter in, sit it up like it's a gauge, go for a drive, read temp gauge, read multimeter, speak to phone and tell it to take notes.
This is the other log file, if only we had exhaust manifold pressure - would understand what's going on a bit better Can you take a screenshot of your wastegate setup in the Kebabtech? Engine Functions --> Boost Control (looks like this):
