Sau Nsw Oran Park South Track Driver Training Day
Anna's car doesn't rip epic skids...
No, I don't think this pic is old quite yet :(
lol.. I absolutely love that shot of my car!! I need it made into a signature!!
Alrighty I have just paid for one entry (my bank is weird so might take a couple of days to come through), il have to wait a couple of days to see if Dave can enter too... but more than likely he will. Both be in my line, so different groups please
NO idea which group as its been a while... will be on semis not slicks though ... I ran a 54 in the 200ZR last time out on south but that car was so busted with no brakes!! Pop me into whatever group, Im probably slower these days :) .... Dave hasn't driven OP at all (I am surprised!) but I am sure he will be faster than me but maybe not at first!!
  • Replies 389
Posted Images
how's the first timer group looking?, I'm 50/50 right now on attending :(
I'm gonna need new tyres soon so hey, maybe get them replaced before the event?
brake pads/fluid
anything else I need to consider?
hey yoyo, unless the tyres are rooted just hold on. they will be even rooteder after the day, and you dont want to smash a brand new set of road tyres on the track.
most people who have been bitted by the bug end up buying seperate rims because semi-slick tyres last longer, are cheaper (per day) and perform much better.
definately bleed the brakes with good fluid like motul rbf600 (or get someone to do it), and replace the pads if they are under 50%, you will put plenty of wear on them if you are giving it a bit (and judging by how you drove at texi I think you will....)
thanks for the advice duncan, believe me it's not a case of not sure about attending, I'll be the first one there lol just I REALLY should be spending this money on my house deposit :D on the other hand, it's gonna be my first and last chance for OP so why not?
my brake pads are still good, just probably want to replace them afterwards for peace of mind is all
tyres...my fronts are almost gone, i'd say 50% tread on outside edge for my fronts, will that pass for the day? rear tyres are still good
other than that my swaybars and springs are on and my exhaust will arrive before then, all I can say is I wish they came before texi :)
how's the first timer group looking?, I'm 50/50 right now on attending :)
brake pads/fluid
I've been doing some research on preparation for club events. Here is a "check list" I found from the BMW Club of Qld. Looks pretty good.
Track_Day_Checklist_Ed1.pdf
cheers eric
fark it count me in I guess, depends on a few things...
I'll take pics of my front tyres and you can tell me if I can run them for the day, cause believe me once you see them they're not gonna last for much longer after that
so my plan is to run out what's left of the stock tyres on the day then just get the tyres replaced after that...
so not looking to set any competitive times, just enjoy the track before it closes and have some fun :D
plus I have some leather driving shoes that I can use, but I doubt they are fireproof, will they be okay?
that's a good checklist.
if my cars not ready by then i wil come and do some recording :(
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
