  • Replies 51
Posted Images
^ i betcha i can beat that hahah
didnt have the handbrake on and driver door was out, car went downhill and hit my neighbours mailbox the car continued on to the middle of the road blocking traffic at both sides. mega ultra fail =(
car was left unscathed thank god
man drifting on a corner like that is pretty pointless. its nothing really like drifting on a track... all it proves is that u can put ur foot down hard half way thru a corner and then straighten..
i once thought i was cool by doing such behaviour
OI (NINJA)- chris tell kerwan he's a tool for trying that kind of shit on public roads and why has he got a gtr badge on a 32 gts-t?
hey, do you know him too lol? do you live around belmont? yeah i used to have a fake GTR badge on my 33 too LMAO i pulled it off a while ago XD is just gay...
Thats smart posting on a fourm that police can check, even having his number plate and confirming he was drifting. be smart before posting atleast cover plates.
Shouldn't have been drifting on public roads then.
Edited by Battery_backup
Shit that is close, did he get out and change his pants???
I've never even done a burnout in my car lol, but im probably more cautious than guys like that
Although he did something freakin stupid, you probably SHOULD cover the plates because people have lost their cars over video footage and such posted on the internet - when cops get wind of it. hes not a sauwa member is he?
Hopefully he's learnt his lesson...
lol
want me to teach you?:P
Sign me up for the class too, :P
I actually don't know how to do a burnout, do you drive with the hand brake on or...???
Actually scrape that driving with the hand brake on idea, my mum once drove with the hand brake on for 30minutes on the free way & all it did was wreck the handbrake but I'm pretty sure I didn't see any burn outs along the way...
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
