Hey all i'm new around these parts been browsing the forums for a while. I've had my Stagea for about 5 weeks now it was purchased stock.
Its a 2000 Model RS four S can't drive it enough loving it at the moment.
Has a few mods now:
FMIC
Pod Filter
Rims and Sub/Amp etc
Just a few pics that were taken on the weekend.
9130_131891375833_584215833_2948392_1833317_n.jpg 9130_131891380833_584215833_2948393_5835958_n.jpg
Cheers
https://www.sau.com.au/forums/topic/287047-my-stagea/
Mention that it was totally stock as a rock when we bought it, since have added, cooling pro fmic, rims, pod filter, gauges and sound sys.
Next mods are exhaust, injectors, bigger turbo an tune bring on the power
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4814253
Has a few mods now:
FMIC
Pod Filter
Cheers
Very clean looking car mate!
Love it! looks like its been very well looked after, keep up the good work!
What pod did you get out of interest?
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4814421
Just using a Blitz pod filter, i have an engine bay photo around but not on my work computer
Cool, how much did that set you back?
I'm looking at buying a pod but are unsure which one I should get... I'm guessing they all do the same thing...
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4814578
How much trouble was the cooling pro fmic to fit? Did it fit up to the stock SMIC pipes ok? Need to move horns/cut bumper etc?
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4815665
Nice stag...Btw did you paint your grill black?looks cool ,I was thinking to do that...
The grill was black when i bought it and i dont think it was painted black either.
The FMIC was an absolute prick to install turned into a 2 night session, the pipes fit, but we had to make new brackets to mount the cooler on so it didnt sit at an angle, we got it so that we didnt have to end up cutting anything. we took off the air conditioning fan because the motor was too big and got in the way of the cooler and the horns were easily moved. Fits like a glove now but it was tedious to say the least.
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4815792
ooh 'eck. not an easy fit to a series 2 then. think I might not go for the cooling pro fmic right away - i'd like to keep my a/c fan.
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4817149
FMIC = good now i know how to put one on it, was a totally F***EN mission to begin so much for a easy session haha. but AC is working fine without the fan we will be putting on a thin davey craig or somthing soon when we get a chance for summer. I figure the the radiator one is drawing a fair bit through anyway
Cooler looks tops and is indeed very stealth even though it is polished silver.
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4817484
Glad it turned out in the end. Matter of interest: have you got a series 2? and did you relocate your transmission cooler? if you didn't move your transmission cooler, do you think it would've made things easier if it had've been out of the way?
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4819791
I can spot an S badge on rear, so no trans-cooler.
My R33 Greddy kit fitted fine, pipes perfect! horns relocated, reo skimmed, hole-sawed, heaps of room for A/c fan when i get one!
Love the grill!
Edited by RED513
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4819809
Yeh its a manual. Um didnt want to trim reo bar as accident an insurance will most probs void it as i remember. Um AC works fine without it an we have had some hot days in last few weeks in bris. Grill looks mint black dunno are they meant to be chrome finish??
car goes good with more boost and specially at night with that cooler, works well good bang for buck upgrade
https://www.sau.com.au/forums/topic/287047-my-stagea/#findComment-4822658
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
