wow thanks. ill give you a call on the weekend as you said :D
at the drifts, look for the gun-metal FG F6 ute (plates SBEC) and the blue R32 with black R34 GTR rims :)
sweet the tyres arnt road wothy ,only good for drifting
and would you beable to get us throw the gate up the top so we could drop them of to you were your drifter is please
and you can ring during sunday arvo
cheers
cheers
works for me, as my street car cant run anything smaller than 18" rims due to brakes anyways :D
ill try, they might be "stingy" at the top gate, but ill try, worst case, ill bring my ute around to the gate :)
thanks heaps !
works for me, as my street car cant run anything smaller than 18" rims due to brakes anyways :)
ill try, they might be "stingy" at the top gate, but ill try, worst case, ill bring my ute around to the gate :D
thanks heaps !
sweet when i get there ill come down and c u and then you can drive the ute up an grab them
and do you want the 255s as well or do you no any one that would want them coz im going to bring them with me as well
cheers you proberly dont need to ring on the weekend
cheers
cheers
ill take the 255s as well :)
cheers matt :D
Shame about your car dying Sam, was hoping to get some pics in for you.
Sorry I didn't turn up till way later; girlfriend decided to come along, so I figured it was best to cut out the extra morning hours.
WADRIFT Round 1 Photos
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
