Check that all the lines are connected.....that would be the only reason as to why it would be over/free boosting.....from memory R32 actuators are meant to hold 10psi all day every day....if that doesnt work then i would certainly try the boost controller method.....and if still not working then i guess the actuator could be shagged....
took iut foir a run and when i camer back looked at the gate and it was open a little and it seems to wanna go past 10 psi could it be cause of the way the piping is from the actuator to the intake piping???
wheres the line with ya finger go ????atm i have a straight piece of pipe go to the in the top cool pipiing ie intake pipe a little be4 throtle bodyi only have one line from actuator tio i c pipe am i spose to have this one that seems to go no where??
Edited by R33NZSL33PA
Take ALL the factory vac lines off. take the 'T' piece out too.
Run ONE line from the intercooler piping to the actuator.
And Put a blank over the hole where the 3rd line would have gone on the intake pipe.
Done.
Here, i know how hard it is sometimes with describing how to route a line on the internet, so hope this helps.
This is Exactly how MY R33 is set up with an R32 actuator. No Solenoids, bleed valves or EBC's. Straight actuator boost.
Everyone loves a good paint jig :)
+1
All you need to do is run a vac line from the wastegate actuator to the intake manifold/pressurised i/c pipe. All the rest of the vac lines can just be blocked off/looped.
Unless the actuator is fecked you should be getting 10psi all day. If you are getting less, do the Rev210 intake mod, as my intake pipe was sucking shut at only ~10psi.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
