Check that all the lines are connected.....that would be the only reason as to why it would be over/free boosting.....from memory R32 actuators are meant to hold 10psi all day every day....if that doesnt work then i would certainly try the boost controller method.....and if still not working then i guess the actuator could be shagged....
took iut foir a run and when i camer back looked at the gate and it was open a little and it seems to wanna go past 10 psi could it be cause of the way the piping is from the actuator to the intake piping???
wheres the line with ya finger go ????atm i have a straight piece of pipe go to the in the top cool pipiing ie intake pipe a little be4 throtle bodyi only have one line from actuator tio i c pipe am i spose to have this one that seems to go no where??
Edited by R33NZSL33PA
Take ALL the factory vac lines off. take the 'T' piece out too.
Run ONE line from the intercooler piping to the actuator.
And Put a blank over the hole where the 3rd line would have gone on the intake pipe.
Done.
Here, i know how hard it is sometimes with describing how to route a line on the internet, so hope this helps.
This is Exactly how MY R33 is set up with an R32 actuator. No Solenoids, bleed valves or EBC's. Straight actuator boost.
Everyone loves a good paint jig :)
+1
All you need to do is run a vac line from the wastegate actuator to the intake manifold/pressurised i/c pipe. All the rest of the vac lines can just be blocked off/looped.
Unless the actuator is fecked you should be getting 10psi all day. If you are getting less, do the Rev210 intake mod, as my intake pipe was sucking shut at only ~10psi.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
