Hey Everyone,
Just a quick update from CV Performance.
We straped Paul's awesome R32 GT-R onto the dyno today for some more tuning.
On 30psi of boost we made 673kw at all four.
The sound of this beast on full noise is something that need to be experienced in person to really appreciate how good it is.
I'm sure Paul will come into this thread later to elaborate on the details of the car.
Enjoy the pics, videos to come later.
  • Replies 57
fark, that's a huge discrepancy. is that after your last tune when you thought you had the issue sorted?
did you get it checked on another dyno and find it to be 55kw down on the CV dyno figure!!!?
there's prob a thread on it somewhere that i missed
yes had it checked on two other dyno's afterwards, both mainline dyno's...just power runs "no difference in tune".
initially went for boost drop issue...was claimed as cleared n sitting at 280rwkw..took it to two dyno's for power runs...came up at 225rwkw-230rwkw...so quite a difference.
freak occurance??
Edited by allthewaytotheskyline
all i can say is this car is absolutely SPASTICCCCCCCCCCCCC on the streets , i drove with it one night when he only has a run in tune 550 kw's and i cannot describe how loud and how awesome it sounded .
well done paul .
Does he run filters on the street ?? If so ....how ? (i assume those really short K&N ones ....) mainly the rear turbo, looks like its pretty tight in there !
Well done though... when does he take it out to the drags ?
Gary
AFR's between 11 and 10.. seems a little rich.
edit: beaten by paul.. curses ! hope your running copper plugs cause they are gonna foul up pretty quickly with that much fuel.
drum of roo on the front seat makes the little rich figure a lot richer...it isn't tuned the same as petrol. i.e. it really likes to be a tad leaner than normal.
there may be a reason or scaling factor error...just surprised me a little thats all
good figure...time to race it now guys.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
