Hey guys I'm selling my Hypergear Turbo as I've upgraded to a bigger one, turbo came off my R33 VGC bought it brand new and has only done about 8,000k's It's a T3 type, 0.63 ar rear housing, will post some more pics up tomorrow.
Located in Vic
$550 ono, will post at buyers expense PM me or post on here,
Cheers guys
https://www.sau.com.au/forums/topic/287272-hypergear-tr43-turbo/
does it bolt up to standard manifold/dump/oil lines? How much power did you make it make? ball bearing? willing to ship to sydney?
yeah mate bolts up to factory manifold, you can have the oil lines as I will no longer need them, but turbo wont fit factory dump, will need a bigger size to suit, and with this turbo it made 201rwkw @13psi, and it's bush bearing not ball, yes will ship anywhere in oz
$400 delivered to Aelaide 5161. If ya keen let me know. Cheers
mate I got offered that amount from someone in my area, if you really want it you can have it for $500 delivered and that's including oil line and dump pipe
hey mate, stupid question but will this fit R34 GTT? and which turbo is better to have, this one or the stock R34.
yeah it will fit but u need custom dump, oil lines etc...which I still have, and the hyper gear would be a good upgrade from the stock turbo as the hyper gear TR43 are good for 440hp.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
