How would these fit?
Would modifications be needed?
What tires would be recommended as well?
Aim: To sit perfectly !!
Size:
Diameter: 18" <li>Width: 9.0" <li>Bolt Pattern: 5 x 114.3 <li>Offset: +30 <li>Hub bore: 67.1
Thanks in advance
https://www.sau.com.au/forums/topic/287309-will-these-rims-fit/
Well 235 is minimum legal width you can run on a 9" rim and 265 is the widest. I dont think it'll sit in the guards. My mate has just bought R34 GTR wheels for his R34 GTT (18X9 +30) and they sit perfectly inline - fronts slightly out. He's running 225s front and 245s rear.
Won't have to roll guards them or anything.
They will fit. Run 235/40R18 all the way around, they are legal for the rim, will look good on the rim and doesn't effect your overall rolling diameter all that much. They are also a reasonably common size and you can pick up some good tread patterns without breaking the budget IMO (Toyo Proxes T1R, Bridgestone RE001 etc.)
you should fit 245/40/18 with that size & offset.
how lowered is your car?
Its on tein coilovers so i can set it to whatever.
But i plan to have it sitting around 1cm under.
Like 1cm of rubber in teh guard if possible.
So perfect/tough kinda look :whistling:
So you think 245/40/18 all round will get this look?
Or will it scrub?
it will fit... go for 235/40/18 all round as its a fair whack cheaper than 245 and the difference in width is absolutely f**k all... you will not notice any extra traction from a 245
I strongly suggest you go 235/40/18 front and 235/35/18 for the rear. I have this on my R33 and I find the tyres just sit slightly out but not outrageously and they look mean in my opinion.
It's all I have right now, sorry. This is with 235/40/18.
i have yokohama s-drives in the same size on the same rim, and they look a fair bit more stretched than this. i know not all '235' tyres are exactly the same width, maybe compare different brands side by side before you buy.
Where/what is the best place to get tyres around sydney arear. Around $200 each tyre.
Thanks
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
