i am also gonna change mine too...my stillen sway bars (F + R) and front strut brace arrived last week...along with my stillen catback exhaust...
did u have to get a customs broker to clear the items? it was a very costly exercise for me...customs, GST, clearance, fees, delivery costed me almost $800 alone!!!
Next time ask the seller to mark the value as less than $1000.
Works every time.
You will get screwed on insurance if they get lost or damaged tho.
hehe you know black beauty right! :blink:
(i sounded bias again just then) :down: hehe
don't blame you man, like I said before your v35 changed my opinion on owning a black car :blink:
as for shipping Siu Loong Bao I'm guessing you had all your stuff arrive at once? I only had to pay for the shipping and swaybars to the vendor and arrived via fedex 3 months later
so the value of goods would've been well under $500 anyway
  • 3 weeks later...
update exhaust is on just in time for Oran Park too!
Fujistubo Legalis R
I'm organising a dyno run soon but the by the butt dyno I could feel a noticable increase in the midrange, top end feels a bit looser now to get too and low down feels the same
This exhaust is sooo quiet it's awesome, it reminds me of my old HKS hi-power silent that I had on my GTT as the idle note wasn't any louder but had a meaner tone to it and when I put my foot down it sounds aggressive without any drone, in fact there's no drone at all, which is exactly what I wanted from it so overall I'm very happy
I feel that this is how the car should have sounded stock as it's not obnoxious at all would still be quiet enough for people who would buy the car for cruising/daily driving
for shuts and guggles eh bro
Yes/No?
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
