  • Replies 203
Not really something I need for the pits... rather diagnostic purposes.
Would someone be willing to lend me their split-fire coils for one day (29th of March) to see if it is a spark issue I am having. Will only be used on a dyno for 1 hour max. Would be hugely appreciated and I can supply beer :no:
Please let me know. Am desperate.
Edit: should probably mention that I need some for S2 R33 ...
Edited by cactus
  • 2 months later...
3" will be ok if under 91 db's. FMIC will be a problem if the reo has been cut (will need a permit). adjustables will be ok if they dont spot them. make sure your clearance is 110mm from ground to lowest part on car
  • 3 weeks later...
Hey guys,
I got a yellow today :) All I got done for and all I need is some rear tyres. It would be great is someone had some cheap stock s14/r33 wheels with decent tyres that I could borrow, or if you are heartless, I can buy cheap.
Cheers,
Ben
Hey all,
well this morning as i am currently waking up i got done by the po po!! they got me for front suspension saying it dosnt have enough rebound lol i laughed,,, and my rear spoiler is longer then the car which i agreed toooo, but now i am in need of parts
i need exhaust cat
standard BOV
i think thats alli need as i have permits for the rest.....
can anyone help?
your reply was very helpful lol..seeing as he posted in the right section?
Haha he didn't, he created a thread for it and the mods moved it here. Not sure why they moved my post though... lol
I have a standard bov if you need to borrow munazza
aww sweet bro i am currently away mate,, i be home early July,,, i shall PM you once i am home...
Hey guys,
Does anyone have a stock R34 cat-back exhaust that I can potentially borrow? I'm assuming standard GTT and GT exhausts are very similar... Anyway, story is that I may be swapping my 2.5" cat-back with a 3.5" one from someone over east, so I would need an exhaust to put on my car while I wait for my new one to arrive.
Would definitely prefer to borrow, but if someone wants to sell one cheap then I may consider buying.
Cheers,
Martin
Hey All,
tommoz is the day i will be taing my car too the pitsbeen such a rush running around for everything,, but i need a pair of rims/tyers that will pass on my car as atm i am sitting on 20'z
if anyone can contact me in regards too this that would be greatly appreciated!
0421 847 552
cheers.
Hey guys,
Cheers,
Martin
i have my cat back sitting in my shed pm me if you still need it
  • 4 weeks later...
Hey guys,
This isn't for the pits, but I am currently trying to track down some Bride/Recaro rails to suit an R34 coupe RWD. Would just like to borrow them to see if they can be fitted to my Sparco seats as the universal rails that came with those seats does not fit my car.
If you have something please give me a call or text asap, 0431047984.
Cheers,
Martin.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
