My 80 series needs a guilt-toy touch. Im sick of my stock 80kw. Feels even less with the 35's
we have a used fully forged 1fz-fe with rods pistons, cams, valves springs intake manifold q45 throttle, injectors, extractor manifold, tripple plate clutch, intercooler pipes and cooler and down pipe and front pipe and full exhaust available here in Abu Dhabi :)
with a big precision turbo on it :) complete. no idea how much though.. il take a pic when i get back to abu dhabi
I had to travel to Qatar for an emergency one day trip, visit a customer here who has a few cars in our shop and get some of my working visa stuff finalised.
waiting at air port for flight back now
will send some pics in a few days
You're gonna be busy!!!!!
What do you think of the Adaptronic E1280?
and to make things worse, i just sold another v88 yesterday... so now we have 3 2jz supra's in our shop's getting Vipec V88's installed.
The adaptronic is a good bit of gear. I put it in the car for testing only, and a quick tune but had to remove it because the car came in for a Motec m600 not a adaptronic.
anyway the Adaptronic ran the engine just as good as the motec and I spent more time with the motec on the final tune then i needed with the adaptronic.
the thing i really enjoyed about the adaptronic was when I had any questions or anything, Andy was there and was keen to change and mix and match things in the software / firmware to get what we needed, I was amazed... it must be the back end of how that ecu is made because he was able to make instant changes with good results on the FLY.
it is a ecu that will go places, I am sure of it!
nah, same model same colour, same engine... different turbo.. completly different customer, this one only had 620 at wheels
we get soo many of these cars its not funny.
The 800hp one?
Hey everyone.
Here is a really good article of our shop, it was made by a English guy who lives and writes 4x4 articles in Russia.
It is a really good read, I am sure you will all like it.
Just to give you guys an idea of the standard work that rolls in and out every day is not anything I ever would have imagined doing 5 years ago, and what really scares me is that it just keeps moving forward and we are just getting more and more work every day.
Project X Motorsports UAE
some exciting news for me today, kinda really pleased with this achievement...
We have a 2012 model nissan patrol in the shop atm, its got a VK56DE engine, its here for a Vi-Pec and full turbo kit.
I managed to start the car today, and get everything working, e-throttle is working fine but i need to work on the setup on it a bit more, now doing some final wiring for the complete install and then we will tune it NA before building the turbo kit.
This engine sounds great! really nice v8 sound...
Also some pics i took at the shop today.
The 2 GTR's are the ones we are doing the turbo kits for, the 2 supra's are here for Vipec V88's and there is a few corvette's in the shop atm also.
enjoy
post-1240-0-29180900-1319928926_thumb.jpg post-1240-0-23410000-1319928937_thumb.jpg
post-1240-0-41297900-1319928944_thumb.jpg post-1240-0-02743100-1319928952_thumb.jpg
post-1240-0-06400600-1319928962_thumb.jpg post-1240-0-77765700-1319928990_thumb.jpg
tuned the fully sick fast and furious supra today, ran outta injectors at 500rwhp on 20psi...
going to do a full works hypertune manifold / throttle setup and fuel rail with ID2000's
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
