i got a silvia here for sale, so heres the details...
3 grand ono
1991 s13 silvia,
rb20det out of a r32
manual with heavy duty clutch
rb25det turbo on it,
lsd,
drift BOV
FMIC and Piping,
16 inch Advantis with new tyres
mod plated
2 tone satin black over primer,
paintwork not that great, could really use a sand and paint, even with the super cheap spray cans would looks pretty good,
a couple of dents on bonnett,
1 dent on front right gaurd and 1 dent back left gaurd. just small ones.
windows all work
2 1/2 inch straight through,
4 inch bee-r cannon,
smoked tail lights,
greddy emanage computer,
factory silvia floor mats,
white trim,
r32 steering wheel,
monza oil catch can,
6 inch rear speakers,
nolathane rear end kit,
the bad points.....
needs to be finished wiring up,
exhast needs to be bolted to back of turbo,
power steering needs to be bolted up,
drive shaft needs to be bolted up,
all up would take half a day to put back together.... iv got all the parts here to do it, just cant find the time....
it was a factory manual sr20de
would be a great track, drift car, or use as a tuff street car,
will upload pixs in next couple of days....
contact 0421940916 or email [email protected]
offers around 3 grand.....
located in south east queensland.... sunshine coast.
https://www.sau.com.au/forums/topic/288062-s13-rb20det-manual/
iv uploaded a few pixs.... more to come though, next day or 2 ill have the rest up.
not currently running or regod, ill take less than 3 for it, just make me an offer.
cheers, aj
ill be keen az on swaps for a c33 shell or a31 shell maybe even a 4 door 32 33 or 34
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
