Heaps Of Parts Rb's, Gearbox's,garrett, Tial Heaps of performance parts, r32,s13,180,s14,rb25 engine,sr20,2jz,rx7
-RB25det long motor 80,000ks from C34 stagea good compression in car, custom high capacity sump no manifolds or turbo etc includes loom moddified to suit plug and play r32 and std ecu $1700 or with out loom and computer $1500
-Garrett 3082R .82 3 weeks old one dyno run mint condition $1600
-Tial Wastegate 44mm v band type one dyno run old$500
-Custom steam pipe manifold to suit RB 20/25 has 44mm tial gate flange and t3 footprint heat wraped same as 6 boost good condition $750
-R32 tien basic coilovers with king springs 12kg fornt and 10kg rear also have std spring rates 1 month old$600
-R32 fr and rear whiteline adjustable sway bars like new $450
-Custom rb 25 inlet plenum suits just jap 80 or 90mm tb also has adapter and std tb fits perfect looks trick =] $600
- Rb25 VPW fuel rail kit and 6x siemens deka 650cc injectors includes rb25 injector loom with plugs to suit $600
-buddyclub P1's 17x8 and x9 with good tires $1100
- white r32 GTR bonnet and grill (aluminium) perfect condition $400
- r32 newish genuine dmax front bar $300
- ca18det ecu - $60
- rb20/25 high mount stanless manifold, brand new never fitted - $250
-ca s13 power steering pump $50
- s13 sr20 turbo brakes with decent pads lines knuckles lwr control arms etc - $150
-s13 sr engine x member $100
-ca radiator gc $40
-sr s13 gc comes with thermos $40
-heaps of turbo bends elbows pipes to suit sr and 25 $20 each
-s14 handbrake and cables $30
-s2 rx7 manual gearbox gc $200
-2jz turbos and manifolds probs need rebuild $50
-s14 greddy air diversion panel a couple small marks dints etc still works good $50
-ca18 loom has one interior plug misisng$50
-set of 4 17x8 skid rims $400
-s14 std steering wheel $50
-s14 std mirrors white $100
-s14 airbox $60
-s14 clutch fan recently serviced and fan shroud $50
-s13 blinker and wiper stalks air bag type $30 ea
-2x cannon mufflers $50 ea
-2x used sr clutches one is nismo solid centre other is exedy sports button average condition might need a machine $50 each
-ca18 auto gearbox tailshaft gc $100
-sr20 manual tail shaft yoke $80
-rb25 top half plenum no tb $30
-s13 clutch pedal and man brake pedal assy $200
-4x16inch r33/s14 std rims 2 are pink 2 are black no tires $150
-r32 nismo strut brace $50
-sr20 std fpr $10
-rb20 std fpr $10
-6 rb20 injectors $100
seriously heaps of stuff need anything ask
will post up more as i think of it
PM me =]
Located on gold coast or ipswich
Hey mate, interested in the RB25. Have you got compression results for it? Does it just need exhaust and intake manifolds and turbo? Anything else? Would you be willing to ship it to Vic?
- ca18det ecu - $60
-ca radiator gc $40
-s14 airbox $60
-sr20 std fpr $10
-rb20 std fpr $10
PM me =]
Hey mate, you still got the fuel rail kit, the injectors, the injector looms and plugs? Keen to take these off your hands, will you be able to organise delivery to Perth?
How old are the injectors and the fuel rail? Ever been fitted?
Would you accept $450 inclusive of freight?
bare 25 is SOLD
sorry mate not as yet still have other interest at asking price..... injectors rrp for 120 ea and fuel rail was 300 thats over 1000 dollars worth of gear with out the plugs speedflow fittings lines etc been used for 3 weeks
I still want the strut brace but you never replied to my PM!!!
hey mate sorry been so busy still here do u need pics? its got red plates and the bar is silver i will get pics to you tonight
pics of the r32 front bar please
will pm you shortly
hey dude cant pm ..not enough posts, have you got any rb coil packs?
yes have a set of super sparks 300ono used for 3 weeks like new
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
