  • Replies 40
Not a bad way to get some aggro out?
you cant hit the ball hard enough :) and if you do it just goes flying off and makes you even more aggro.
the driving range in narrabundah is best for aggro release. what about a driving range day?
At this stage lets make it the 17th. Although I'm not sure if I can make that date lol (on call). But someone else can get us all organised on the day lol
booked in for 17th oct 1:30pm, need 10 people for special rates
13$ for 18 holes or 11$ for 9 holes + free equipment hire ( normally 5 dollars, otherwise 5$ for equipment hire)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
