My GTRS turbo's arrived today. I took some snaps to show all. I am really happy with the GTRS kit, everything included.
(Sorry but I could not post up the jpg's)
Anyway, they go onto the car Next monday and hopefully the car gets tuned before the drift day.
https://www.sau.com.au/forums/topic/28909-my-bad-boys-are-here-gtrs-turbos/
  • Replies 64
OK,
The mods.
Apexi PFC & Boost controler.
The GTRS's
550cc inj
HKS dumps
3.5in exhaust
Cam sprockets
3000lb brass button clutch
custom FMIC 760x360x72
Fuel Reg (To be done at turbo install)
Oil cooler
3 plate brass radiator
Sump baffel and head restrictor
Metal Gaskit kit
I hope to get the car tuned thursday next week.
I will probably stop at 1.2bar as I dont drag, just track days
I'm sorry but you musn't be looking in the right places if you beleive there isn't much info on GT-RS turbines on the RB26?!?!?! *baffle*
In fact, i think there is ONLY info available from manufacturers about the RB26 and the SR20.
Freely available on the manufacturers site :(
Adrian
Yeh there is info from manufacturers, but next to no feedback from owners in Aus of GTRs with these turbos fitted...i think that more what he meant. :(
Cant wait to see how your car goes with these turbos, perhaps with all this grunt its time you spend some coin on new shocks? :)
Does the kit come with its own wastegate actuators? and do these turbos bolt up to the standard HKS dump pipes or do they have there own dump pipes because the wastegate outlet looks different to all the other GT25 series turbos the wastegate does not look completely seperate from the turbine wheel
Yep, they come with their own internal wastegate actuators - as pictured set at 0.9 bar. The wastegate outlet looks different because there is a 'splitter' to stop turbulance from the main exhaust outlet. They will still bolt up to the standard T25 5 bolt dump pipe.
Well the turbo's are on and feel nice. Lots more low down torque and agressive top end. With a new set of plugs it is a new car!
I have only been to 1bar but felt very strong, I am very happy. Dyno tomorrow and check the Fuel:Air and see what power I get once the PFC is tunned. I am looking for more of a fat curve that a peak power curve. Usable power is the key for me.
The only negatives, the turbo's are a little louder that the standards and really scream once they are spooled up. Also the waste gate has a vent at about .8 Bar so I cant drop the boost when the wife drives. Oh well, as small price to pay. So far 5 star rate on the turbo's
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
