  • 3 weeks later...
  • Replies 64
Well All, the verdict is in. The GTRS's are a bit big for a standard GTR donk, If I was to do it again, GTSS would be the go. The exhaust hausing on the GTRS is just on the too large side and for the 1.3lt worth of air.
Yesterday I went down to UAS, to get it dynoed and tuned.
Firstly Ben from UAS was fantastic! and I will defiantly get him to tune my apexi again. His attitude to tunning was constructive, conservative and worked with you openly, sharing ideas and experiences. We discussed most changes before doing them and he was always happy to tune as I asked, but always explained clearly why he personally would or would not do it that way. As a bonus I learnt heaps over the time and he knows his sh!t.
In the 4hrs of Dyno time, we set 4 boost setting, tried about 10 different Cam adjustments combo's and played with heaps of fuel and timing maps. Both cruising and cold start runs were completed. The car had a base timing at –5 Deg to start with, so the first job of the day was to get the Apexi reading the same as the timing gun.
Fuel, we played at around 12:1 but then riched it up for safety at about 11.8 to 11.9.
Boost setting on the Apexi, were set at follows.
.7Bar (God knows how, as the GTRS turbo's was suppose to have a 1Bar actuator?)
1Bar
1.2Bar
1.4Bar
At all boost settings we tuned to about 10 knock and at 19psi it was just under 20 knock, which is really safe.
Now for the power figures, remember this is a 2WD Dyno, Im very much looking forward to testing on a 4WD dyno to see what the actual drive train losses are on 4 paws.
Starting Dyno 29 Deg outside temp last night.
236KW, Default apexi with the mods listed in the 4th post.
Today at lunch outside temp was 34 Deg and were settled runs on a hot engine. BP Ultimate, not additives.
10 PSI (.7Bar) (Who cares, this one is only for the missus)
14.5 PSI (1Bar) 250Kw
17 PSI (1.2Bar) 280Kw
19 PSI (1.4Bar) 300Kw
We decided no to go any higher on the boost, and added some fuel and retarded for safety to ensure the engine does not go pop. It’s not worth 10 kW on a dyno graph, if it costs you an engine. We got a peak spike of 330Kw at one stage, which was our highest reading for the day.
The best CAM sprocket settings were at +6 and -6 Deg, the GTRS keep the top end high and the sprockets added about 5-15 KW though the 3000-6000rpm marks. While the peak power only dropped by about 5kw.
My duty cycle topped at about 75% so there is heaps of fuel still in the inj. I could probably put the STD ones back in if I really wanted too.
The bad news? The bad boys are very laggie, I did not hit 1bar of boost until 5000RPM, but then they would sing. Target boost was hit about 6000rpm.
The good news was the dyno graph was unbelievably linear. The thing drives like a STD GTR around the street, and then when you hand the rev's up, you know your not in a STD car. It should suit my day to day driving and keep me happy on the track when I sit around 5-7000 rpm.
The GTR needs to be bought by someone who want to do some serious work to it. Cams, forged oversized pistons, 3lt bottom end. The turbo's are capable of 100+ more kW if the engine was set up to use it.
All in all Im happy and assured of the cars longevity, I will run day to day at 17 PSI so it will be fun.
Again, my praise to Ben from UAS, job well done. And John thanks for looking after me on the price.
I will post up the dyno info once UAS send it to me.
My standard Sr20 spools a GT3540 with GT42 compressor @ 4,500 RPM which is around the same HP rating as 2 GTS-R turbos. If not more. Full boost by 4,700rpm.
A rb26 that spools 2x GTS-R should spool better then my car
Interesting results to say the least!
Looks like your results concur with the GTROC UK guys who have had extensive testing on the GT-RS over several cars and found that they are only suitable for 2.8L and up
I'd love to be able to post how my GT-SS turbos go soon, but my mod list keeps growing and now I'm waiting for forged conrods to arrive :P
It will be another month AT LEAST before my build even starts :crying:
Hi OZGTR97V, 1 bar at 5,000 rpm would be 4,200 rpm with an RB31. My cams come on a little learlier than that and with 9 to 1 compression ratio, I reckon maybe even 1 bar at 4,000 rpm. A pair of GTRS's have gotta be worth looking at.
Next time i whore a ride around Eastern your likely to scare the pants off me with the new found power...congrats.
:P
Not wanting to start a dyno debate, but what sort of dyno do UAS have (Shootout mode???etc etc)
Yeh, Ben is on the balll, only have to look at his little 1.6L which is probably quicker then most cars on this forum.;)
Ben's "little 1.6L" has a LOT of thoughtful and ingenious modifications. Open the engine (boot lid? :P) and you'll see why it runs so well, with much more to go as well!
Also, new dynodynamics software version was rolled out late last year, and apparently Shootout Mode is the ONLY mode to use now for the most consistent readings with accurate corrections to take into account atmospheric factors. This is apparently what DynoDynamics training staff are telling all their customers (the workshops we goto)...
Yeh James (Groove Rider Fabrications) does nice work, certainly a well thought out and well built/tuned car. ;)
For everyones info.
.....................Compressor......................Turbine
....................Trim...Inducer....Exducer...Exducer...Inducer....Trim
GT2530..........63____1.860____2.344___1.883____2.098____76
GTRS.............52____1.997____2.773___1.833____2.098____76
GT2835..........52____1.997____2.773___2.020____2.204____84
GT2540..........46____2.016____2.972___1.833____2.098____76
What size turbine housings are fitted? what type of exhaust?
The reason I ask is it appears from your dyno that you arent getting the gas velocity needed to spin the turbos up. the boost response is very gradual, which is very uncharacteristic for HKS GT series turbos, that tend to hit pretty hard when they come on boost.
Few things come to mind, either turbine housings are too big, exhaust is generating too much back pressure, manifold poorly designed, or all three - assuming the tune is OK.
I don't want to offend but i would be fairly disappointed with a graph like that, they don't seem to be any different than the 2540's. 301kw @ 19psi is definitely a good result but that midrange is just hopeless mate.
+6 on the inlet cam timing is certainly quite different, to far advance i would've thought.
Can anyone explain the values on the bottom of the page regarding the shootout settings.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
