I can't agree with you there .
Garretts own GT30 and GT35 (small frame GT BB versions) maps show you that the flow rates are similar between the GT30 turbine in their 1.06 A/R turbine housing and the GT35 turbine in their bored out 0.82 A/R GT30 turbine housing .
The links to the turbine maps .
http://www.turbobygarrett.com/turbobygarre...amp;3turb_e.jpg
http://www.turbobygarrett.com/turbobygarre...8-allturb_e.jpg
It looks to me like the GT30 turbine in the 1.06 housing size has less restriction in the lower pressure ratio zone than the GT35 has in the 0.82 housing .
The fact that the three lines in the 35's map are a gentle curve rather than a sharp rise to a point and flat lining tells me that the GT35 turbine is too big for the GT30 family turbine housings .
Purpose built (OEM) GT35 turbine based turbos use GT40 family turbine housings and not surprisingly their GT40 compressors live in GT40 compressor housings .
Cheers A .
Edited by discopotato03
  • Replies 55
All i say is that i love my combo the way it is! :)
It's a 525hp turbo and i'm squeezing 330rwkw out of it, so i'm pretty sure i'm maxing it out; hence why the boost drops as the rpms increase. Once max flow, of a turbo, is reached; any increase in rpm needs to result in a decrease in boost, as you can't have more than maximum flow. (hope that makes sense)
When i'm making over 235rwkw and over 8600N of tractive torque @100km/h, what do i have to complain about :D
Just fitted the GT3076R to an RB25/30.
Engine management is Haltech S2000, closed loop boost control.
Turbo kit came with standard Garrett 5psi actuator.
Can only peak briefly at 18psi then drops to 15. 310 rwkw max.
Really would like 330 - 340
Another example here is Als. Pretty much a similar engine to mine, injector sizes, cams, only he opted for the 15psi actuator.
However Al only gained an extra 2 psi across the graph, and our curves are identical, same peak and drop, but he's got 20 kw more.
Is this the typical symptom of the IW 3076 ? or is it still crap actuators ?
If I was to fit a large can 18 psi actuator, could I achieve 21 psi flat line.
Also wouldn't mind boost to come on a little earlier
Please don't tell me to go External wastegate.
Cheers.
Just ordered the 18psi Large can Garrett actuator from ATP.
Currently 310 rwkw with GT3076R RB25/30
555 cc injectors, 256 Poncams, 044, Haltech S2000, Plasmaman 72mm TB
Anyone wanna predict the kws with an extra 6 or 7 psi.
:D
Hate to thread hijack but better than starting a new one. Does anyone have any pics of their dump/front setup with a iw gt30? I've got a bellmouth one at the moment but it seams way too restrictive, looking for ideas for a new one. Thanks
  • 1 month later...
:down:
PROBLEM SOLVED :D
Large can actuator fitted.
Had to re-thread it to attach it to my lever. No big deal.
Holding 22 psi flat as f$#@
Could get 24 out of it but injectors are maxed.
Full boost also 700 rpm sooner than before, response is just brilliant.
336.7 rwkw and 1120 Nm
Gets up and goes like a 15 year old boy havin his first root.
Edited by conan7772
what do these actuators cost?
$59 US plus $20 freight from the states.
Couldn't find any in Oz
ATP have em.
Rated at 18psi but we can dial it down to 14.
The large can is better for response and tunability.
ATP have em.
Got a link? Would this suit a Ford GT35?
PROBLEM SOLVED :)
Top work conan.
I saw the same issue with mine before/after cams. Held the same max 17psi regardless that it was making 30rwkw more. Big head actuator problem solvered.
Also saw the same on a mates GT35r .82 at around 300rwkw even though a GT35r at 300rwkw is hardly working. Stiffer actuators are the way to go on IW turbos.
Edited by SLAPS
ATP have em.
Hi mate,
I'm running a 3076r too and was wondering if the above mentioned actuator is a straight fit replacement?
Depends on the setup... Std exh manifold will require a slight kink to be placed in the rod.
Aftermarket.. well that depends on your specific setup.
The 18psi large can actuator has a straight rod - have a look at yours and see if there is a kink in the rod or if its straight.
As for bolt up. Providing there is clearance it will bolt up.
Thanks mate,
My 3076R has a bent rod and i'm using a custom low mount manifold...how would i be able to use the straight rod 18psi actuator in this case?
ok so shipping from ATP is $95 - f**k that!!! Is that what you paid conan? It would cost them $20us max for express
I spoke to MTQ they have a "small can" 19psi actuator there for $135 does that sound like it would do the job?
I am getting my car tuned in a couple of weeks and want to try remove every possible weakness before it goes on the rollers
RB30DET with internal gate XR6 GT35R currently holding 15psi with the standard actuator but next tune i want to up it to 22psi so thinking I will need the higher PSI actuator
What is the benefit of "Large Can" ?
No mate, send ATP an email to sales, say that you want this item and ask for a standard freight to Australia.
Forget tracking or registered postage. It's only an $60 item
I mentioned the excessive shipping for such a small item and they returned to me with $20 US for shipping.
Ask for a full invoice with instructions for payment and that's it.
Large can holds higher boost pressures more accurately, provides better response and tunability.
You won't be disappointed and the cost is bugger all. Took 10 days to arrive.
We can tune it from 14 to 24 psi flat line. That's pretty damn good tunability for an actuator.
We had to cut the straight rod and re-thread it to connect to my waste gate lever.
I'll take some pics tomorrow...
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
