for big power the RB26 head is better. but you also need a new wiring loom and possibly ecu depending on what you go with.
i hope you have set aside 20k+ for the build.
yeah i was thinking the same but then i seen them built for $6000NZ here http://www.dodsonmotorsport.com/index.php?...l-products.html or i could get one for $6000aus from an unfinished project sale atleast i would have most of the work done i will most likey change a few things to make it stronger what do you think deal or rubbish?
Edited by R33Gtst Driver
call and ask them the price for that engine. there is no way you are going to get a forged bottom end, full turbo setup and dry sump for $6k NZ the parts alone are worth double that and then some.
for that kind of money expect a bare stock internal RB30DET long engine.
all the info i foun on prices for parts on that engine build were all atleast a few years old i figured the price might have dropped or they just didnt use the best parts but your probly right which sucks
IMHO -
- Read the SAU forums re the build.
- Speak to a mechanic who's built more than one, preferably many. Get a written/detailed quote.
- Chat at length with someone who is driving one and go for a ride.
- ask the owner the FULL cost. This will vary from the quote you get.
dollar for dollar, I reckon a street car is better off with the 25 head with VCT. You get the benefit of all that extra torque coming on progressively and earlier. And for a road registered street car you couldn't want for a better package. It's the way I was/will be going. with WMI and a forged unit and the right turbo you've got to be good for 350-450rwkw and thats healthy for a rwd.
while he already has a 25 head for 600+hp (which is what he seems to want) a 26 head is a far better starting point than a 25 head as you can fit much higher lift cams due to the solid lifters as opposed to spending lots of money to convert the 25 head to solid lifters.
by your sig you appear to have an RB25 head already. check out the RB30 sticky and see what power people are getting. a 25/30 will provide way more power than a rwd can handle so the extra cost of an RB26 head is not bang for $.
thanks ill take a look and i dont know how good my current motor is internally it has already been cooked badly once which is why im shopping for new engine rather then taking a chance on it and i thought it was better off starting with rb30det because either way i was gonna spend a lot forging it
i was thinking along similar line based on the info i have found on the net
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
