I have available 20" Chrome Spinners which I believe will fit Skyline, any one who has fitted 20 Wheels to Skyline might be able to advise the rim Width and Offset they run. My company imports these from the USA, we fit them mainly on SUV, however I am sure they would look mad on Skyline, have a look at the picture's attached and if any one wants to try out will do a special deal for the first one who gets me information in correct skyline PCD and ET in 20"
BBSF1
Chris
Check em out at www.oasiswheels.com
https://www.sau.com.au/forums/topic/28964-20-spinners-for-skyline/
BBSF1
Chris
PCD = 5x114.3 (for 5 stud skylines, ie all turbo models)
Offset is different for GTR's, Gtsts and R32,33 and 34....
Christian
chaos - if they are something like that you'd want to make sure they had really good bearings and shafts mounting the outter assembly that spins.. Wouldn't want to be doing a good speed with these things on.
But if the outside isn't mounted separately then They're pretty cool. :cheers:
are these the wheels that when the car stops moving part of the mag still spins?
nah this aint them. I seen them on a 4x4 BMW down the coast was pretty mad stuff, thought this would be an american thing. You seen these before??
Yes they are! In fact these are commonly known as "Choppers". I was going to get em for the Benz, some 6months ago, but changed my mind. Well it good to see someones sellings these in AU. I really think they'll be a hit. Pretty pricy, in comparison but they look awesome when the car is stopped & the chopper is still spinning.
PS: If I remember correctly, I also think you can buy just the chopper which gets attached to your stock rim :D
I like them.. but you gotta have the car to match.
Theo fitted them to his X5 on the Coast and yeah they look the goods.. but I think he also came away with a defect for them.. (oh well)
would take a pretty special (different) skyline to make them really work. I tossed up fitting them to the Rx7 as it will also have a dedicated set of race rims..
and may still do so..
rim wise you are really going to get a set and see what you can do, what you are prepared to cut etc.. cos I don't see them fitting on and the car sitting nicely without significant mods..
and the car has to sit right over these.. or it will look terrible.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
