hey guys i read around a bit in these forums, people say the headlights on a 06 will fit 03 models, so im just wondering will the back lights also fit? Also what would be the price be for a set of 06 headlights (labour not included) and what the cost would be to place them in by a pro?
anyone got any direct comparison pics of 03 and 06 headlights and back lights they could post up, i've googled but no dice.
https://www.sau.com.au/forums/topic/289683-headlights-back-lights-06-on-03/
06 headlights have projector lenses for the main beam. They are slightly rearranged, the vertical strip doesnt light up.
Pictures of my car:
2003 lights -
2006 lights -
Very nice upgrade but they are NOT cheap. Expect about $1,000.
Tail lights on the 06 model are, well, not flat. Check out this one on carsales.
http://www.carsales.com.au/Tig/UI/PagePopu...mp;tabID=304744
i like the vertical light up on the 03 though the look of the 06 lights overall look better but i dont think id waste my 1k on lights though...just me though others might and probably have.
ps awesome looking V there - love the wheels clean cut.
Thanks mate.
In person, the 2006 headlights look a lot better than the 2003 ones. I've had lots of comments about the car looking more modern with them.
But anyway, the main point of them is for the projector lenses so that you can use HIDs properly.. you can always do a retrofit like 350gtfrank
Also the tail lights on the 06 have a boot release button. Not sure if this can be connected up to 03 easily though?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
