wassup guys n girls
ok running out of patience,space,time and most of all money, as well as starting tafe and buying a new daily. ive decided to put my s13 project up for sale as i cant see myself finishing it anytime soon.
anyway heres the details.
1991 Nissan Silvia s13, Black
sr20det, 5speed Manual
Rego till Mar 2010 VIC
120xxx K's on body
97xxx k's on motor
Engine
Stock SR20det serviced every 5k
T25
Turboback 3" GKTech Exhaust system
FMIC 300x600
ISC 52mm Alloy Race Radiator
Pod Filter
Bosch 040 Fuel Pump
HKS BOV
GK Tech Overflow bottle
new battery and my attempt at a battery clamp :P.
Suspension,Brakes& Drivetrain
BC Coilovers ER (external Reservoir) type (brand new 0k's)
F&R big Swaybars (brand new 0k's)
F&R Strutbrace (brand new 0k's)
Front Chassis Brace (brand new 0k's)
solid steering spacer
R32 gtst brakes all round retain 4 stud pattern
r33 handbrake cables with eagle style adapter plate
s15 Booster
r32gtst Brake master cylinder
Brake Master Cylinder stopper (brand new 0k's)
Stainless Steel Braided brake lines to suit (brand new 0k's)
locked r180 6 bolt diff with fresh diff oil (freshly welded)
Bodywork
floor stripped sound deadning and repainted black, interior re installed with carpets ect.
solid urethane subframe bushes racespec (brand new 0k's)
solid alloy gearbox mount racespec (brand new 0k's)
solid engine mount racespec (brand new 0k's)
full polyurethane chassis mounting kit, front&rear knuckles steering rack pretty much anything that has a rubber bushing has new urethane ones(brand new 0k's)
lipped gaurds F&R
Wheels
Koya drift teks
17x8 +34 with 225/40 maxxis 75%
17x9 +35 with 235/40 potenza re01 $90 ($500 new 3 months ago)
Interior
bride brix 1.5 drivers seat navy w/black gradiant perfect no rips or anything
GK tech S/wheel
Trust gear knob
Trust/Greedy Boost Gauge
Drift HB Knob (brand new 0k's)
180sx floor mats
blue led cluster proper multi directional LEDs looks fully xr-6 turbo hectik bro.
plus more...
As the car stands, i have taken out the gearbox and clutch/flywheel/tailshaft and all associated bits as i has a orc 409 on order.
also front and rear brakes & knuckles, but im in the process of putting them back on to get it rolling, exhuast is out from cat back and most of the new mods not installed.
bonnet is off to work easier, but apart from that it is complete in every way.
basically all it needs is to be put back together, as i have everything there to make it drivable again. Im not looking to part it out just yet.
also have a heap of spares that will come with it, such as standard brakes, springs, seats, half shafts,diffs, ss manifold, arms ect ect..
Ive spent over 20k on this easy, 5k in the last month.
asking $7500 ono no swaps
will post up pics tommorow
https://www.sau.com.au/forums/topic/289853-s13-trackstreet-project/
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
