  • 4 weeks later...
I've finally got hold of a really good and durable aluminum jack that is sufficiently low and deep. Works great everywhere, both in the garage and to bring to the track events.
* Heavy Duty 1814kg (1.8 tons EU) (2 US Tons) Capacity
* Side Mounted Handles (easy positioning)
* Quick Lift Design - 5 Pumps to Top
* Wide Track Wheels & Castors
* Rubber Saddle Pad Protects Vehicle
* Foam Bumper Handle Pad Protects Hands & Vehicle Dual Return Springs
* Low Lift Height - 89mm
* High Lift Height - 498mm
* Overall Length - 673mm
* Chassis Width - 330mm
* Handle Length - 1350mm
* Weight 22kg
Arcan Jack
  • 3 weeks later...
The jack has been tested successfully.
Mounted some of the braces from Ultra Racing. They are spot on.
50mm rear over fenders. At the time being lots of Camber to adjust. Original fenders shall be partly cut away and welded and then all body parts will be glued in their final places.
The front end of the car has appeared rather empty for a while but now I have picked up the front bumper at Thomas paintshop (well done Thomas). I will cut away som minor areas inside the opening to make a snug fit for the intercooler but would anyway like to show you some quick motivating pictures.
  • 3 weeks later...
  • 3 weeks later...
Thanks mate, it's taking a while but it moves on forward :)
It is now time to make the fuel and oil lines.
12 meters of stainless steel braided Teflon line for E85 with 40pcs AN8-couplings and 6 meters of stainless steel braided oil hose with about 10pcs AN10-couplings.
  • 2 months later...
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
