Hey guys just gonna resurrect this post :P
I finally got around to looking at the coil pack, I found that one cylinder (coil pack) had this white residue in the clip. I only changed that one coil pack and it seems to running fine :(
My quick question- is this a coil pack related problem or should I be changing the actual lead it self?
Thanks again
yer it was in the clip from the coil to the loom. Thats wat i done and to date its fine! no more miss fire- its amazing wat something like a coil can do to the car performance. wanted to make sure- cause that plastic is B*tch to take off and on :D
thank you to everyone and once again thank for your input.
if ur car is misfiring, it does not mean u have a faulty ignition system, any slight modification can cause this, on a stock car yes. Changing ur exhaust can create a misfire as it changes the turbulance going in and out of the cylinder, which puts more strain on the ignition sys.
A fix would be replace plugs, gap if boosted, then swap coils one by one and test
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
