  • 3 weeks later...
Not really much happening of late on this. Got some dyno time last week where we ran into issues with the head lifting. So off comes the head to sus it out and go again.
Car went 520rwph at 22psi before the head lifted. Hopefully more updates this week
  • 3 weeks later...
So finally brought the car home for a little while while i fit up some parts and enjoy the car for a bit, even if it is on low boost. Here's a vid of the cars first start up at home along with the exhaust tone at idle.
  • Like 1
First job was to test fit the catch can and make sure it all fits. Had to move my oil filter relocator as that was taking up the space the new can is going. I was limited by the existing line length so after having a look over the setup i was able to mount it under the car behind the cooler piping.
First off i had to buy all the lines and fittings. Anyone who's done this knows unfortunately this shit aint cheap :(
CC874A49-4996-460F-8A6D-8F3E611372D3_zps
Now the new Filter location
3C448AE7-5B2C-4E0F-9DCE-0B0870CD7096_zps
F5A928EF-6EB3-4CF1-8C4B-46F686351CCA_zps
Heres what its like with the front bar on. Nice and covered so it wont get hit with rocks etc. Might still make up a protection case to go around it yet
8A455487-C5BA-4F49-A9C2-1BCCE9250238_zps
And test fitted the can in the bay too
D234FF7F-2989-4912-8F38-B8796AF1D191_zps
  • Like 1
Cars looking awesome man! Been following it for a while now and it just keeps getting better and better, i was just wondering where you got the plate thats holding your coilpacks in place/ how much it was
Thanks mate! Been a bloody long road but its all part of the fun.
Coil pack bracket is a custom job that i got a fabricator mate to knock up. Wasnt the cheapest but I think it looks awesome and give its a very neat professional look
Yeah man it definitely makes it look alot cleaner, ive seen a few other setups with Ls coilpacks where they were mounted on the fire wall and it makes it look messy, im looking at doing it the same way you have just to keep it all tidy.
Few different LS coil options out there. Most of the people who are mounting them on the firewall or off the rocker cover are probably using LS1 coils. Mine are LS2 truck coils, different design and make up and are a lot smaller and user friendly.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
