First test drive proved very enjoyable. Driving a big stalled auto is definitely a lot different to a manual setup.
Saturday Night Roll Racing at Queensland Raceway back on the 14th was the cars first event. Anyone not familiar with this event up here, it's an awesome and relatively new social racing event similar to a happy laps or powercruise session. People line up in the staging lanes and in pairs roll around to the main straight and drag each other. The nights very social and is as fun off the track as it is on the track.
a few days prior to the event I got a fabricator mate to pop around and we had some late night fab fun putting a side pipe on the car. Personally I think it turned out awesome. Bolts on and off just after the gutted cat is tucked up high on the car for good clearance.
A2B4CEC3-EB4A-404A-9788-383FB88F6E6F_zps
Here is the side pipe when its off the car
0684DA69-87CD-4030-8C02-C3C781128137_zps
Some of it on the car
F7BDEDA5-C558-44B0-9E0D-67BE75C1740B_zps
FD22848F-8A5F-474B-AFA8-8D0E747BE2AA_zps
Now for the idle video!!
  • Like 1
Now it was time to actually take the car out there and have some fun with it. To be honest I was more nervous than I thought I would be, it was excited nervous but nervous all the time. Took the first few runs relatively easy just to get a feel for the new setup and how it would react, specially the gearbox.
Mates got a video of the maiden run for the car. Wins a win even if its not overly fast
  • Like 1
Took a mate for a ride later in the night and got an in car video of a race. As you can hear 2nd gear is a bit of a write off as it just wanted to break traction and get loose. New to the setup I decided it best to get out of it and back on it rather than drive though it.
All in all the night was awesome and got a great felling of accomplishment finally getting the car out to an event. Few teething issues here and there to sort out like any brand new build but all in all a successful first night out.
  • Like 1
What power is it making on e85 again?
Currently tune is very mild. 500rwhp at 25psi. TH400 is a power sucker, however the cams that are in the head are too small for the size of the turbo and we arent seeing good enough gains per PSI of boost we are adding so we brought it back to have fun at the track last weekend.
Cams are In:264 Ex:272. Inlet is the big killer
Turbo: 80mm Billet Turbocharger
  • Like 1
More info on crank trigger setup please.
Some good photos of it a few pages back.
Both cam and crank triggers use Honeywell GT 101 sensors. There is also a small 12 tooth trigger wheel that sits between the balancer and the timing belt cog
  • 3 weeks later...
Pretty quiet on the car front for the last few weeks, busy moving house and life in general.
Contemplating a few different things to change on the car. Typical RB life has me pushing decent amounts of oil into the catch can. Thinking of putting on a "Pre catch can catch can" i guess you could call it. Here is a few mock up pics of what it would be. Hoping that gravity helps keep at least some of the oil inside the covers lol
C5194459-8246-4942-A86E-EFF4CB7F1901_zps
4A533956-FD9E-44B1-A379-F02FF61E4F5A_zps
174C7A81-788B-4F8B-9583-7E793D50E6CD_zps
  • 6 months later...
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
