hey guys im in the process of doing an rb25 conversion.
basically i have got to the stage where i can start the car and with a few throttle pumps it will idle fine but as soon as the engine goes over 1500rpm and the pedal is let off it will stall, it revs up to 4k rpm fine(haven't tried to go higher but it most likely would) but will stall once you back off.
im also getting a little bit of flutter which is strange cause im running the stock BOV, i am using the rb20 crossover pipe and BOV because the rb25 didn't come with one.
i have adjusted the timing with a timing light to 15 degrees.
i have done the majority of the wiring except engine light, water temp, wipers....
the engine was rebuilt 15000ks ago and has been sitting around on a stand for around a year.
i have an exhaust leak between the dump and front pipe due to not having a gasket but i wouldn't expect this to cause the problem i am having
im not %100 on the alignment of the timing belt as i didn't do it.
is there wiring or something i could have missed that would cause this stalling?
https://www.sau.com.au/forums/topic/290551-r32-rb25-conversion-troubles/
Water temp may be an issue. Some cars (when the wire is not connected) assume the engine is warmed up. If it's not, the ignition timing and fuel will be out until the car does warm up.
*edit: Get the check engine light up. Once you do that you can read the codes and that will tell you what else the computer needs to see*
Edited by BLSTIC
doesnt the RB20 make more boost than the RB25? wouldnt that throw out the stock RB20 BOV and maybe cause flutter?
just an idea..
yeh but it will stall even after revving it to 1500rpm and then backing off, there is no boost at 1500rpm.
i do think it could have something to do with the vacuum/cooler pipe system though.
as for boost control i have welded a nipple into the cooler pipe that comes off the turbo which runs to the boost controller then to the actuator this is correct?
has anyone got a diagram or something of all the piping?
i have a consult display but i haven't got consult wired yet, ill do this and then i can check for errors.
i also have a spare afm i will try, im using an rb20 afm which im told works fine with a S1 r33.
been mucking around with it abit more noticed i don't have the socket end of 6 pin plug circled here i have the 8 pin but only one half of the 6 pin which seems to run back into the main loom... anyone know what its for, ill trace it but im short on time at the moment.
not my car it will never be so clean!!
tried to get consult working, the thing power's up but cant connect to ecu.
i have a sucking noise coming from the pod on idle i think this is normal but i didn't get it with the rb20.
i get a bit of smoke on idle whiteish blue very fuel-ish smell.
i also fitted up the r33 throttle cable and didn't need any modding like some have described.
Edited by battery
That could be your problem. That part of the loom runs down to the Idle Air Control Valve and knock sensors. You need to separate that plug and wiring from the R33 starter/alternator loom as they are taped together. Im guessing you used the R32 starter/alternator loom so it plugged straight in and thats fine.
yeh i used the r32 starter loom, i checked the 33 one for the other end of that plug but its not there, this could be because this side of the loom was modified.
so it defiantly goes into the r33 starter motor loom?
hmm
my 15 year old cousin came over and is like why don't you try the rb20 ECU and i said naa won't do shit but i did it anyway and it works no stalling, timing is way out of course and i won't drive it with the rb20 ecu.
meh i think i might just go get the rb20 ecu remapped and look at some other way of controlling VCT later....
or maybe its possible the r33 ecu i have is stuffed.... don't have access to another one to test though.
i did trace back those wires , 2 of them are for the knock sensors and 3 are ground the last one i can't seem to find.
Hey mate, I think the one you are not able to find is for aux air control valve (blue plug). Also the only difference between 32 & 33 ECU's is 2 injectors
(no. 4 & 6 I think...) are reversed & obviously the lack of VCT. Doing same conversion right now. Good luck...
  • 4 weeks later...
the 8 pin plug is for the injector loom, the 6 pin plus is part of the alternator and starter loom on an R33, you NEED to cut the knock sensors out the loom and fit them to your motor, while it wont cure your stall issues, you'll need them to make sure the thing runs safely.
have you cleaned the idle control valve at the back of the manifold? start with this it's possible the solenoid is gummed up a bit. brake cleaner works a treat
yeh sorry guys i did find the solution it was a dud ECU, as far as that plug goes i just used a resistor trick for the knock sensors as the engine doesn't have any installed... i might put them in one day if i can be bothered but im not sure if ill have to remove the plenum to get access..
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
