  • Replies 41
hey Steve, on my 34 the car misses on idle when the gap is 0.8 with the copper plugs .. 1.0 gap and no worries.
Hamish, I actually WANT to use a 1.1 gap for better combustion/power/fuel eco .. :P One of the reasons I got the splitfires.
most people gap to 0.8 with splitfires anyway....
TBH it might work @ 1.1 but with that plenum in the way i aint gonna bother to find out :P
heat range 7 seems to be the go too for 200+rwkw stenve... although 6 is quite popular and works on many a gtt/gtst
did it miss instantly? or could you have fouled them?
I've had heat range 6 and 7 in my 190rwkw R34 .. 7's give a slightly better fuel eco I think but apart from that they're both about the same. Unigroup were encouraging me to stick with 7s at this power level and I think they know what they are talking about. I'd give the 6s a miss unless your skyline is completely stock.
Johnny which ones are you talking about, the BCPR7ES-11's ?
found the BCPR7ES-11's at local repco just down the road .. woops, shoulda checked there first :whistling: $31 for 6, all goodah
Told you so :D
They're quite easy to get a hand on!
From memory it appeared to miss instantly (well about 30seconds or so after i started it), but i cant be sure. car isn't tuned yet so its possible i fouled them. (could be a loose loom connection, badly seated coilpack etc, bit of dirt or something as well)
I thought about gapping them back up to 1.0mm, but its odd that it didn't miss with the 7 heat range plugs at a 0.7mm gap :S i was under the impression the smaller the gap the worse the idle?
just called the local repco and ordered in the BCPR7ES-11's for me.
so tomorrow i'll throw them in at a 0.8mm gap i guess? what do you guys reckon? (running splitfires)
dont really feel like taking them in and out if it doesn't work haha. is it better to run them at 1.1mm gap if i can?
tony (munkyboy) runs the 7's at 1.1mm (i think) and he hasn't had an issue, but he has only just gotten some yellow jacket coils or whatever they are called
yeah 1.1mm with new coilpacks. but thats only at 13psi. i think i'll be going to 0.9mm for 16-18psi, and hope it holds up on the dyno.
looks like ive joined the 1.1mm club
just finished up and took it for a spin.
put it the bcpr7es-11's checked all the gaps, they were at 1.1mm then didn't touch them
took out the bcpr6es put in new plugs carefully hooked everything up and tada!
no more miss at idle, car seems to pull a lot easier, seemed a bit more powerful (probs just cause i was breaking traction on the wet roads all the time haha)
im running 12psi max. usually peaks about 11.5psi and no sign of a miss anywhere.
so there ya go if you are running splitfires at max 12psi, in "theory" you should be able to run 1.1mm gaps
how'd you go wacky dee?
just waiting for my splitfires to arrive and a date with unigroup ... I'm gonna do the same as you (same boost as well..11.5psi sometimes 12max depending on weather I guess) Good to hear you're not having any issues.
What did you use to check the gap on the new plugs? I checked with repco and they had those feelers but max .8mm or so (5 different kinds all maxed out at under 1mm)
lol. you add the different thicknesses together to make the amount you want. ie. 0.8 with a 0.3 or as close as you can. put them together, and check the gap.
yeah, what he said.
Dont worry i looked at it for a minute and went "wtf?"
Has anyone had issues with 7's fouling for normal street use?
I run BKR6E at 1.1mm on street (95%) and 7's at .9mm when it gets the boot in - 250rwkw+. I have remote mounted coils so swapping out plugs is a 5 minute job.
Is the OEM plug the same height as the BCP or the BKR? Maybe the BCP are actually too tall and put stress on the coils?
well im having the same issue as Stenve.....put in bcpr6es gapped to .8mm and now it misses.....at the start it would only miss when it warmed up...but now it misses from the time i start the car....
i have a little over 200kw s2 r33....have jjr coils....should i be running bigger or smaller gap??? and should I be using the 7???
thanks!!
6s will do the job ..but 7s are probably better for > 200rwkw and put the gap back up to .9 or 1mm and you should be ok. If that doesn't fix it, one or more of your jjr coils are dodgy.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
