I am looking to have a Skyline GTS-T inspected later this week by the NRMA, but a quick search of this forum just returned some rather unexpected negative comments on their work.
As I am living in South Australia and the car is in New South Wales, I don't know of any better places for it to be inspected. Can any of you NSW folk put forward some suggestions (preferably of a place near Blacktown, 2148)? Or have the NRMA gotten better lately?
MotaCheck in South Australia is supposedly very good, but they are not a national company.
Thank-you in advance.
https://www.sau.com.au/forums/topic/29063-nrma-inspections/
When I was selling my Lancer, the guy who ended up buying it got an inspection done and he basically listed everything that I knew was wrong with my car. I was really impressed but also pissed off cos it meant I had to sell for a lower price.
https://www.sau.com.au/forums/topic/29063-nrma-inspections/#findComment-596886
Just called the NRMA. The inspection will be $339.00, which does not include a compression test.
The owner of the vehicle I am having inspected is confident that it will pass. Is it common practice for the cost of inspections to be split, or is it up to the buyer?
i would've thought it'd be different in every case. i guess the seller doesnt have to sell it to you if he doesnt want to? its almost taken as a priviledge to sell it to you in some seller's minds!
i didnt think there was a "pass" or "fail" grade they gave, they just simply give a report :P the pass or fail is ultimately in the mind of the buyer? :)
https://www.sau.com.au/forums/topic/29063-nrma-inspections/#findComment-596905
When I bought my car from Sydney (I live in Canberra) I was looking at an NRMA check, but for the same price Hills Motorsports would check it over and do a compression test etc.
If he/she is willing to take it to somewhere like this (Hills Motorsport, Croydons, Advanced Imports etc) it would be of more value to you than NRMA, as they work with imports all day long and would specifically know what to look at on the car for any problems.
Make sure you get the rego + vin + engine number as well so you can revs check it... last thing you want is a car under finance and the seller 'do the harry' on you and not pay off the finance and the car is then repossessed off you :P
https://www.sau.com.au/forums/topic/29063-nrma-inspections/#findComment-596919
yup great advice here....C&V can also be of help.
https://www.sau.com.au/forums/topic/29063-nrma-inspections/#findComment-596953
This might help you out.
I sold my GTS-T early this year and the buyer chose CRD at Silverwater for the inspection. I have to say I was impessed with how thoroughly they checked the car over for the buyer. Everything from Compression tests to dynoing to road tests including checking every single switch and electrical device in the car. A complete report was also issued with the results of the inspection.
They would definarely be a good place to go if you want the peice of mind of having the car totally checked out rather than some half baked NRMA inspection that doesnt provide you with enough information.
Edit: CRD charged around $200 for this service (good value)
https://www.sau.com.au/forums/topic/29063-nrma-inspections/#findComment-596969
actually I had NRMA inspect mine too since at the time I didnt know a workshop to take it to.
I am happy that the report I got was complete, they do see far more imports these days than a few years ago.
https://www.sau.com.au/forums/topic/29063-nrma-inspections/#findComment-597173
Sydney Vehicle Checking are very good.
I've used them about 5 times in the past and are always impressed with their professionalism.
One thing that NRMA does NOT do is check the panels for bog.
Syd Vehicle checking do...they go over every panel with their magnet tester... Saved me from buying a complete write off..looked perfect but had been through those hail storms and bogged up cheap.. I couldn't tell but they could.
Also, with the Skyline I bought, they inspected it, checked all panels...all good, except they could tell that the white on the front right guarrd was different to the other white panels...maybe panel replaced or resprayed due to scratching.
Even after he pointed it out, i couldn't tell.
they are cheaper too but not in the way they do things. Give em a call!!
http://www.sydneyvehiclecheck.com.au/
https://www.sau.com.au/forums/topic/29063-nrma-inspections/#findComment-597196
$339.00 is definitely the NRMA member price. Keep in mind that this price would only be around $190.00 if we were talking Australian delivered cars.
I will have a look at this web-site Brinie, but will probably end up calling the NRMA at 9.00am to arrange an inspection through them.
https://www.sau.com.au/forums/topic/29063-nrma-inspections/#findComment-597279
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
