I got 2 gearbox's that crunch into 4th gear. There is a syncro clip that comes out when you shift into 4th too quick.
does anyone know the part number for this or know where I can buy some? i need about 5 of them.
cheers
  • Replies 60
no its a syncro clip that brakes and falls into the oil. when you change the oil you can see it on the magnet.
this is a known issue with 25 box's. so where can i get the parts to replace mine?
p/n fast comes up with is, 32609-70L70. there is 3 of them.
i was having the same plobem with 3rd and 4th crunching, My 3rd syncro ring was worn and my 4th was cracked.
cheers
do you have a picture of these clips? what do they look like ?
what came out of my gearbox does not look like a ring
thanks for your help man, but thiis looks different to what came out of my gearbox.
here are the pics
post-1240-1254908068_thumb.jpgpost-1240-1254908107_thumb.jpg post-1240-1254908170_thumb.jpg
in one of my other box's that this happened to only the small clip part came off and it crunch's into 4th gear. it does not crunch every time. about 60% of the time.
any ideas?
just went and took a pic.
Guilt - those clips look the same as in my R32 gtr box that i have the bell housing off at the moment.
what are they ? whats the part number? what do they do? how do you replace them?
they are on the 4th gear syncro, i dont know what they do but i can ask someone who will know. Only reason i know is i was having issue selecting 4th when i took my housing off and was looking at them when I was trying to figure out what was wrong.
Can't find them in fast, but I think there is 3 of them. I think they are on the 5th gear synchro hub. i will look at mine tomorrow.
The only things on the 3rd and 4th synchro hub are the 3 shift inserts, and 2 insert springs.
here are the pics
any ideas?
Yeah they are the reason why this is happening. they hold the syncro in place or something? I am not sure. But i know there is one guy in sydney who knows the issue and he repaires them for $250. but i am in Eastern europe now i cant exactly chuck 2 box's in the back of my car and cruise down to him.. i mean the skyline can fly but not that far :dry:
That would be good. please help. I have 3 gearbox's here that need this repair done on them and we cannot exactly take it to a local guy to find the issue and parts and sort it out. we can take him the box with the parts we need installed but thats about it.
my 33 gtr box crunches 4th too, every other gear is very smooth tho, i wish wat u are suggesting here is true coz id do it straight away! just need to know how to do it lol
Yes its true, its from shifting from 3rd to 4th gear too fast. it has happened to a few of my box's and a few others that i know of.
We need to get to the bottom of this!!!
that happens to me as well GT, i always thought it was either shi*t gb oil or worn synchro.
i will keep an eye on this thread incase you find the answer cause it worries me that my gb might blow 4th gear lol.
nah the box won't break the gear. eventually you will wear out the syncro and it will get worse so that means if you fix the clip issue it will still crunch because the syncro will be worn out.
We need answers! someone help us with the info we need. I am sure this is a quick and easy fix and once we get part numbers I will get pics and give all the info i can when i repair the box's here.
Here is a message i got from PJ a while back about fixing this issue.
I removed his number from the PM, I am sure he wont appreciate his number being put on a public forum.
I did talk to George and he is able to fix the box's for around $300 i believe. If someone is keen to get there's done and need his number then please send me a PM, maybe if you go to him with a box that needs the repair and ask him for the details and part number to get the parts to do the job he may help us out?
Sadly I am not in a situation on the other side of the globe to do that.
anyone keen?
Give George from Advanced Motor Mechanics in Enfield a call 0402 *** ****
They do all the mechanical work on my beast.
If your 4th gear syncro is hammered, replacing the clips won't stop the crunching though...
Cheers
Paul
I had a look at mine today, those clips that you put a pic up of, are only on my 5th gear synchro hub. My 1st -2nd and 3rd-4th synchro hubs only have the shift inserts. (the ones in the pic I put up )
my gearbox is a 5/98 model which is a bit different than the early models and maybe this is one of the different things.
Edited by woolls
is it possible that those clips hold all the syncro's together and causes the 4th gear crunching?
those clips are from the sliding hub that selects gears. 3rd and 4th are f**ked. box has to come out, remove the bell housing, remove the input shaft from the mainshaft and you will find that the sliding hub outside part will just fall off
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
