Since you've done so much damage, why don't you just get another neo from a wrecker and go again. It only died because your oil was on the track. I think a neo with a good sump will last for ages. 90% of rb's die from oil starvation of some description, or a bad tune. Don't see too many die from being pushed too far
i would but i cant find any around for a reasonable price... im not paying 2.5-3K for just a motor like some wreckers want,
mercuary motorsport proved you can push 700 hp from a stock neo and then subject it to drag racing for a while with their VC commo they built for a customer.. i dare say the rods and pistions are strong things!
i shall start a slow build of another block i have on the side... will get it ready for next year
Yeah the things that kill RBs are almost always oil related, fix that and you'll have a very reliable motor, nissan knew how to build them better than a lot of builders out there. I'd trust some guy that built 20 motor a day for years over some muppet that takes your $10k of parts and gets the clearances wrong.
i would have found a way to make it work lol.
well good news anyway i got my new crank tested, fitted with crank collar, ACL race mains and big end bearings supplied, and maching of crank for 400... not a bad price! just need to re-assy. check tolerances and then put it back together
Who is doing the engine work for you champ?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
