well crank is back in... got my rods resized with ARP bolts and they go back in today... it should all be back together this weekend. with the crank i had it in and out no less then 15 times measuring and checking bearing clearances... we then had to do some work to make sure they were all spot on. time consuming stuff.
update!!
motor re assembled by myself.. bearing clearances checked. everything all good. and motor back in the car. started it up tonight after priming it up for oil pressure and it fired first go and sounded great! got it up to temp and it seems to have slightly more oil pressure then before and rev's and idles smoother then ever.
skid performed :P
some updates... been busy last few weeks working on my trailer doing brake upgrade, new hubs, GTST rims, new tyres, and a few other things. oh and new 4meter long ramps :D
in between i have been doing a few things here and there to my car. some pics here
10W super bright LED's with a 45degree spread. got these for the trailer which i will mount on my new nose cone facing backwards... it really is a PAIN in the arse loading and unloading at night so these will help a bit!
mounted a sheet of alloy for an understray cooling panel. simple yet effective.
and again
lock stops... had to do a two step part as it was slipping under the LCA on hard lock.
what the rim is scraping when on lock
machined lip lol
getting ready for ADGP next weekend
so my new brakes on the car trailer had a hiccup... i neglected to check hose to rim clearance.. and one rubbed thro. got f**k all clearance there not sure what i'll do.
another
my new ramps.. they are 4 meter scaffolding planks. they require a support in the middle to stop the sagging but they work a treat.
mounted light!
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
