Needs side skirts and front bar support yet
Had it on the dyno yesterday.. had some normal teething issues and some not so normal once.. had oil leaks and coolant leaks everywhere...including a leak from the radiator :/ anyway sorted that shit out and then started the run in process. the engine was run in for a bit with some hard core load by holding it at 4000 rpm and then increasing the load, did that for a bit and its sweet... engine runs and sounds great. however once we started getting into the tune we found it would just missfire like crazy at anything over 4000 rpm and 12 psi boost.
Decs tried pulling fuel and timing out, adding fuel and timing and a combination of both, nothing made a difference. we tried gapping the plugs down to 0.5mm then 0.8 and then 1.2mm. none made it better. Coil packs were brand new 34 GTR Splitfires. only thing we can put it down to was faulty coilpacks.. so that effectively ended it for me. On top of this drama i have a clutch that doesnt disengage properly.
as you have just rewired it your miss fire may be being caused by electrical interference into the CAS wiring. running the 2 white shielded wires near the coil packs or to close to the injectors or anything that may cause electrical "noise" can make the ecu miss read the signals. when i wire rotaries it is very important that the ignition wiring and crank signal wiring are separate as they are prone to misfire then killing engines.
i have also had CAS die randomly and they will cause an under load fault. checking on the ecu shows it should have X amount of timing but checking with a timing light shows actual ignition timing far less. will be fine untill load is applied.
im sure you have checked it but fuel pressure will also cause a miss under load. not sure if you have put a gauge in it yet but as your lift pump was faulty you may still have an issue. depending what brand E85 you are using it may be killing your pumps/injectors. i know of local racers that have had 2 or 3 pumps go in as many events due to the brand/quality of E85. this is because E85 is Hydroscopic and will take in water. E85 manufactures are allowed to add a small amount of H2O to the mix but this can and will cause seizures of pumps and injectors.
hope that gives you a few leads if you done have it sussed already.
new loom is a haltech loom, comes with shielded cables for the CAS and triggers. Cas wiring runs under the intake manifold where as the ignition wiring runs from behind the head straight to the valley cover. I doubt thats the issue. We initially thought a faulty CAS or wandering signal might have been the issue... i held a timing light on the timing marks while decs ran it up to the point where it would missfire and the timing did not move around at all.
fuel pressure is spot on.. 40psi at idle and rises to 60 psi by 4000 rpm + boost pressure. does not move at all also.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
