Thanks for the review mate.
.... any advice for someone who is about to set up an s13 to learn to drift in?
I've been reading a lot of info on drift set up's, but not too much info on what a good beginner set up might be. also, a good proportion of the info out there is contrary to most of what I know about suspension (open wheel/circle track style cars).
It has cusco coil-overs, caster arms and rear camber arms.
Cheers
Justin
all you need is coilovers, a diff that locks both wheels reliably, and a seat that holds you tight. the rest is not needed. save the money and spend it on tyres and seat time.
seat time is what makes you a better driver.. not the sum of the parts listed on the car
While I agree with Simon, in regards to setup, if I was just starting out, this is what I would do. (I don't mean to hi-jack)
Firstly, keep the car at a reasonable height. Max out the front camber. If you want, you could run s14 lca's for more track and even some eccentric clevis bolts for more front camber and better sai. Run 7-8 degrees of castor and 6 or so mm of toe out to help with turn in. Rack spacers are a quick, cheap and easy way to get more lock. There's no need for knuckles when starting out. A tight or shimmed lsd is a good starter, don't start out with a welded diff. A gtr rear sway bar would be a good addition. Start out with zero toe on the rear and work your way in as you get more comfortable. Same goes for rear camber, and standing the wheels more upright. But most importantly don't forget to have fun. Oh, and keep an eye on those temps.
Hope that helps.
i have a similar yet different opinion.
for any S or R chassis... if you want to learn to drift all you need is the 3 basics.
-coilovers
-bucket seat to hold you tight
-an LSD that works
power, other susp mods and anything else isnt needed in this early stage... better off saving cash, buy tyres and hit the track. learn the basics and develop skills.. then upgrade accordingly
more work done today..
cut out the rear shelf to start building the ducting box
Cut the lip off the inner wheel well to allow clearance at lock.. will then run a weld over it to strengthen back up
New GKtech V3 castor rods! looks the good
made up rails for the velo passenger seat i have,.. both my seats are old and due for replacement. but that will come in good time. for now i'll continue to rock them.. so comfty!
then i welded up the chassis rail after cutting the lip off to give extra clearance.. i then ground it back flush and painted it up.. quite shit to weld since its thin and far from clean material.
I also cut the lip off the firewall above where the head would be to make the engine install an easier process.. welded it up and linished it back.
my welding rig.. gets shit done!
car is now at the painters!
i got myself a Kouki wing for it, will look good once painted and fitted i think. Spent yesterday chopping rear guards inner and outer skin. bashing it up and then welding new sheet metal in to fill the gap. was an absolute prick of a job, then used sikaflex panel bond to seal the whole thing all the way around to minimise smoke entering cabin.
with the car at the painters not much has been happening at home.. so i broke the 31 out the shed and started working on that. fitted s13 suspension and coils to it, just need to fit manual trans, do cooler piping and shes almost ready for some skids. I'll probably skid it a few times and then sell it off.
an arty shot of my motor with my cat on it... haha
1012459_10201104969319747_1715676515_n.j
Some parts from GKtech rocked up also! pretty much got a heap of bushes and so forth for chassis bracing. They sent me a bash plate but unsure if it will fit. will prob require modification since RB and all.
GKtech also just released these sway bar links which are solid.
  • 4 weeks later...
bit of an update... car is all painted and now we've started on all the mechanicals n 3 weeks the car is getting a whole new ecu and loom. Full rewire. Fuel lines. Coolant lines being made. Ducting and shrouding for rad. As well as various mechanical bits and pieces. Garage7 have got this!
I decided to sell the Haltech as we got a fantastic deal on a new Link G4+ extreme, probably one of the best ecu's on the market, big call i know but the list of things that this can do is crazy.
Some pics.
On top of this i have been driving my missile r31 lately which is basic as hell. weldie with s13 coilovers, SMDrift knuckles, rb30e+t making 165 rwkw. Qualified 4th and finished 4th at Stadium drift round 3.
you can read up on it here
http://www.smdrift.com.au/1/post/2013/09/stadium-drift-rd-3-2013.html
been super busy, had a heap of time off work so spent last week and a half working on it each day getting a solid 8 hours + done each day. engine loom is all done and its Pro town! Done by Steve at Garage7 who was taught by Declan how to do it, Loom uses nylon sleeve with 3:1 glue lined heat shrink as the bulk of it. not a single bit of elec tape used haha. We also used quality Deutsch plugs (DT series connectors - google it) through out. Today we fired up the loom/ecu combo and made it all live, good to know everything works. a few hours were spent calibrating and configuring it all, so now when it comes time to crank it over it should in theory fire first crank.
Body loom is yet to be done, Decs from Garage7 has designed a laser cut switch panel which is very aviation style and mounted on the roof just behind the front cage tube with all the switches, push start and so forth. the cool thing with the Link g4+ is you can use one button to start and stop the engine. just push it and it primes the pump, cranks the engine until it fires and then keeps it running. push again to kill it. just like a lot of new cars these days!
also spent time mounting the GKtech hydro handbrake, tomorrow i'll make some custom brake lines up for the rear brakes and then all that is left is fuel lines and coolant lines + shrouding of the rear rad. all of which is being laser cut atm.
updates!
Wiring of switch panel and fuse/relay panel is underway! all parts designed by Garage7 and laser cut to suit! looks amazing!
Shrouds for both sides of the radiator done.. fan attached and all sealed up.. it pulls a HUGE amount of air!
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
