Vct Controller For Rb20 And Non Vct Enabled Ecus On Rb25s, Anyone Interested?
I'm a computer systems engineer so myself and a friend are going to create a module for my rb20 ecu + nistune that runs an rb25det to switch on the VCT solenoid.
We will work on an experimental design over the next few months (not difficult but need to find time) that will switch the VCT solenoid on from 1500-5000rpm (stock range).
The board will tap into the tacho pin out on the ECU and then via a little PCB turn on the VCT at the appropriate range. We will implement two pots to allow changing the upper and lower ranges of the VCT so you can turn it on from say 2000-4000rpm or whatever, allowing you to experiment on the dyno to find what works best for you. So basically it will turn on when you have some throttle open (eg tps is measuring something, don't need to advance the cam when you are idling or backing off throttle) and when the tacho pin is in range.
Now I am going to do this for myself no matter what as I want to see how useful it is, but if there is interest we would probably sell a proper PCB in a box for ~$50-60 with instructions. I've spoken to Shaun at boostworx and he thinks the VCT is good for 5-10kw in the mid range when enabled.
Now this is purely an idea at the moment, I will work on some schematics tonight and see how easily it can be done, and how the RPM out pin works on the RB20 ECUs to see how hard it will be to do.
So people, anyone interested in one if we make it?
Edited by Rolls
rolls, great idea.
I have been playing with VCT for a while and have experimented with tps switching and afm voltage switching. (using load insted of RPM) to switch. but had to many variables in driving conditions to see if it made any real world difference. I even played with cam timing in the intake cam. and what I found was that switching via rpm and leaving the range stock was the best option, atleast for a 30det.
I am sure there will be a few interested in this
Think there is already some products out there that can do this but they arent cheap. I will keep this thread updated. I wrote the code to do it last night, but need to design the hardware and get my actual ECU so I can meter out the waveforms on an oscilloscope before I can really make something. Should have an update in a week or two.
Interesting to hear you have already played with it. I think I will aim for a basic model at first that just has static timing the same as stock, eg 30% throttle and 1500-5000 rpm it is switched on, however I should be able to easily make a model that you can vary the upper and lower rpm, along with the throttle percentage, just that it probably won't be that useful if we find that the stock variables work best everytime.
Edited by Rolls
I'm open to volunteers that have equipment already running that I can test with. Basically be nice to have an already wired up VCT so that I can measure voltages and waveforms etc, hell if anyone has electronics/programming experience we can make this a group project.
I'm in Adelaide so PM me if you think you could help out.
Use an atmega processor I'll write the code for you already using one as an ecu for a 2 stroke quad bike very easily done
Its ok I've got 100s of projects written for PICs. I coded up a solution in an hour last night, this is the easy part, just need to figure out the input waveforms and whether I need op amps to transform them into a useful range, this is more where i need help, the electronics side. Ill post up a schematic soon with some source code so people can see what I'm trying to do with the data.
we use a kit from jaycar pretty sure its 25-35 bucks so best check it out before you bust your nuts doing the same thing. :rant:
Edited by URAS
Either way I can still build one for under $10 so I will probably do it myself as I do stuff like this everyday for my job (I find it fun), but it wouldn't be worth selling it for less than $50. So maybe look into this if you guys want something now.
Edited by Rolls
ive got a product which i bought a few years back for a customers car for a different purpose. We used it to switch LPG on and off at a specified RPM windown for a turbo diesel patrol.
i'll grab a photo if you want.
Thats cool, I'm more after the voltage ranges and waveforms of the tacho signal and the TPS signal. So basically I can translate volts or hz to rpm and volts to throttle percentage. I can meter this out myself once I get my stock ecu + nistune installed but I have a wolf in there atm so it's a bit more difficult.
Anyway looks like theres already stuff on the market if people want this now. I will still make my design and maybe put the design on the net so people can DIY on the cheap for ~$15. See how we go anyway.
when i was looking, there was nothing lol. seems to be a few around now.
If you make something, and its easy to use, people will buy it! even if its more then the jaycar ones.
The one i have has dip switches for setting various hertz ranges for either rpm or voltage imputs. its complex to set up.
Initially I will hard code it in software what throttle percentage and rpm range to turn it on/off at. Eg stock as stock. Then will add features to adjust lower,upper ranges and tps setting.
Edited by Rolls
Even if you can't sell it any information posted would be great. Just built an RB20 with an RB20 PowerFC but looking at going RB25 as soon as I kill this. I want to keep the computer as the FC's are rare and its much easier to keep the RB20 ECU than rewire in a RB25 one.
given the complexity i dont get why you would reinvent the wheel
if jaycar make a off the shelf thing, and from memory they do
then this would be perfect
With the work I do this is a piece of piss. I do it for a hobby, I get satisfaction out of making something myself. Same reason some people build cars instead of buying one already completed for half the price.
The jaycar item does not work exactly for this purpose either, it will be more complicated to use.
Edited by Rolls
  • 5 months later...
Ive designed a PCB and its working but I had a set back with my car and money so I haven't actually been able to test it.
The stock ECU and nistune only got fitted a few days ago to it so once I have it on the road I will be able to wire it up and start testing. Not sure of a timeline, basically whenever I get free time off uni I will work on it.
Will let everyone know once I get something useful working.
edit: I can post up the schematic if anyone here can program PICs and wants to have a play themselves.
Edited by Rolls
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
