hey guys, on the way home just then i was giving it abit of stick, and then it started making noises and was struggling to reach high rpm so every time i tryed to reach rpm and making a struggling sound...current mod fmic and just got boost controller today, i didnt check the engine bay to look for loose pipping because its too dark. but im paranoid now..any ideas?
https://www.sau.com.au/forums/topic/291327-wierd-noises-help/
struggling sound?????? more info, check ur pipes, boost control hoses, remove controller, start from there, new cooler second hand, new cooler or second hand
just had alook at the engine bay seems fine, no pipes out. yer when i give it to it, it struggles to hit high revs. when i got it in hi boost it does it bad, but when i got it on off mode just a minor bit. wouldnt be coz i got stock ecu?
Did you read what I posted? Also, how much boost are you running?
it only happens when i hit high boost, i read a few threads with similar problems and it results in coilpacks, but i dont want to buy them unless im 99% sure :S. by the way if you have faulty coil packs does that mean you get less km's from a tank? because ive been getting less km's recently
question guys, insted of making a new thread i thought id ask here. ive pretty much come to the conclusion my coil packs are on there way out. now im abit short on cash so i was thinking is it worth getting brand new nissan coil packs from justjap or should i save for yellow jackets. would the stock nissan coil packs handle my mods?
take it to a proffesionall
Sighh............ :laugh:
There are a couple wonderful tutorials in the DIY section about fixing coil packs yourself. Lowering the gap is a good idea too (on new plugs). Don't bother spending hundereds of $ until you have exhausted your $free.99 options first. DIY section. Search.
before you go looking at coils, pull your plugs out and see what gap they are and what condition they are in. if they are 1.1mm plugs and have been in there for quite a while they may have worn and the gap may be bigger than 1.1mm so just putting new plugs in will solve the problem and only cost you about $30.
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
