G,day, finaly got L2S but not sure where to go from here, Im looking at doing track days-gymkhana type events and stuff but not sure whats needed for anything else, CAMS website is useless as I cannot find any other info.
Any info is most appreciated
https://www.sau.com.au/forums/topic/291527-l2s-licence/
don't need anything else unless you are looking to drive for an actual competetive race team. L2S licenses only cover you for club drive days, which CAMS classes as 'driver training days', hence why no actual door-to-door racing takes place
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4874653
L2S is for sprints, supersprints, hillclimbs, touring road events with speed tests, khanacross etc up to National Championship level.
CAMS class them as speed events.
You will need an extinguisher, blue triangle indicating battery position, and secondary bonnet restraint (depending on scrutineer's interpretation) as a minimum on a road registered car.
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4875362
Now you just have to wait till an event comes up and enter it!!
...and where do we wait for these events to come up? The track websites are hopeless, unless an event is listed in the nsw/events section how else do we find out about these events being held? I'd love to try a hillclimb but dont even know where the hillclimb tracks are let alone how I can participate.
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4875745
google "hillclimb nsw"??? pretty sure there is a site dedicated to the NSW hillclimb championship which will have all the clubs contact details you need. most will run club rounds as well. Get onto their mailing lists and your set.
there are heaps of venues in NSW. 2 at Bathurst run by Bathurst Light Car Club, King Edward Park at Newcastle (MG), Bulladelah (sp? & no idea what club that is) are a few that instantly spring to mind.
Edited by hrd-hr30
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4875779
Ben,
Other car clubs!
the other club Im with - Southern Sporting - they do everything, supersprints, hill climbs, skid pans and can even get you into MRA
Otherwise there are state rounds such as supersprints and motorkhana's with their dedicated websites
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4877334
If you want the events that are on go to the cams website under the clubs ection under events & pick your state:
http://www.cams.com.au/Sport/Events/Event%...;to=&page=1
As for the secondary bonnet restraints - I have never had anything other than the standard bonnet - no clips, belts or any other 'secondary device'. Reason being is there are two restraints already built in to the bonnet - which is why you have to pop the bonnet then go around the front & release it.
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4877500
as I said, depending on scrutineer's interpretation. JZA80 Supras have 2 seperate catches standard, one on either side of the bonnet, but some CAMS scrutineers still wanted another form of bonnet restraint! better to have one and not need it than vice versa.
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4879926
Ben,,,unfortunately you can't wait for events to come up. If you are interested in doing state hillclimbs and or supersprints you really need to register for them. That way you get e-mails giving you all the forms and dates. The state supersprints usually allow 100 cars a meeting and we had 140 registed entrants this year so not only do you have to be quick entering but if your not registed you have almost no hope. Hillclimbs on the other hand are almost never booked out,,,in fact they can't get enough entrants.
Here's 2 sites for your perusal.
http://www.supersprints.com.au/
http://www.hillclimbnsw.com/index.html
Harry in NSW our scruts are happy with a standard Skyline locking system,,,your sructs must be arseholes.
Neil.
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4880701
with your bonnet restraint, secondary, rather than drilling holes and fitting bonnet pins etc, and ruining the body work, you can quite adequately use a mens leather type waist belt, ie something sort of strong, with a buckle thingy, loop it through the top radiator support panel, and then through one of the holes in the ribbing on the underside of the bonnet, ( you may need to carefully cut a slit in the underbonnet ribbing, if there isnt two holes near each other/, then, almost close bonnet, reach hands in, do up bucle and finally close bonnet.
i am a CAMS Scrutineer, this is sufficient for the type of motor sport you will use the L2S for
The idea is to not have the bonnet fly up and block vision, etc.
Even front hinged bonnets, when a car is going off the track BACKWARDS, can fly open, I have seen it done on a Datsun 240Z and a Mazda RX2
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4880835
in regards to bonnet restraints, if you have bonnet pins does each one count as a restraint as they are independent from each other?
Yes. Problem is, if you forget one pin, you're going to forget the other one aren't you? So then if you go out on track forgetting to lock your bonnet pins, whammo! Bonnet in your face. Seen it happen plenty of times. Keeping the standard latch in place has it's advantages.
If you use bonnet pins without the standard latch, you just have to be dilligent and do a check before heading onto the track.
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4883554
the intercooler now sits where the latch use to be.. however i have placed some springs around the pins so that you have to push the bonnet down when putting them in, otherwise it sits up a fair bit.
Thanks!
https://www.sau.com.au/forums/topic/291527-l2s-licence/#findComment-4883957
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
