Hey guys!
Here to introduce myself!!!
Have just purchased an R33 GTS-t. Newly imported 96 model. It us both my first Skyline and first import, and fast becoming an obsession! Though I did have to leave it and travel the day after I bought it :D looking forward to getting back and going for a cruise!
Thought i'd sign up to look out for upcoming events and meets. :D I love meeting new ppl!
Shooting a photoshoot with my car once the front bar gets it's respray and then I will have loads of hot pics!!! :D
Located in nth Ryde if other members in the area.
Cheers!
Samantha
https://www.sau.com.au/forums/topic/291534-be-gentle-newb/
  • Replies 139
I had the lube out! but really, welcome and have fun in here. The wasteland is where all the cool kids hang out.
We're pretty rad really.
Haha thanks!
I like to go among rad people!!!
Don't put the lube away yet.. The pics are comin..... lol
https://www.sau.com.au/forums/topic/291534-be-gentle-newb/#findComment-4878816
Since I was asked so nicely by RBNT I have uploaded ONE shot to my gallery.... I have none with my car yet, still waiting on the photographer, but since u are clearly curious u will have to settle for "back to school"....
Keep an eye out for me out cruising in my hot, black '33 with white RIMs...
Keep on rockin!
Sam
https://www.sau.com.au/forums/topic/291534-be-gentle-newb/#findComment-4885531
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
