I was at my local Autobarn store over the weekend and I saw some Drift GTR style seats (like the 34 ones?)
Have any of you guys got these seats? What do you think of them? Pros/Cons
At $449 each they are obviously a lot cheaper than genuine items and they felt ok and are comfortable, the only thing is Im not sure if they are ADR approved.
Any thoughts?
https://www.sau.com.au/forums/topic/291574-drift-gtr-style-seats/
Hey dave i think the main con for any of the cheap replica seats (autobarn/justjap) is they dont come with proper rails only univeral ones which will cost a few hundred each to get modified to suit your car.
i would like a set of 33gtr seat for my 33 but a good set is like $1000-1200 but they bolt straight in.
cheers Rich
ppl just use bride rails and they fit on the eastbear ones, havent had a look at the DRIFT seats but i assume it might be the case with these too.
they are ADR approved & come with lifetime warranty on the frame, wow, cant go wrong there.
google DRIFT seats and visit their website for more info :P
this was the seat i was going to get but instead got a Recaro.
btw, which Autobarn did you go to? cause $449 is a good price, they were $499 when i enquired about them earlier this year.
eastbear copies have rails made for them, so straight fit if you buy the rails to suit. Bride rails arent much cheaper if at all.
i have a stock 33 seat at the shop, i'll try to have a look at it this week, see how hard it is to remove the rail from the seat on those.
if its not too bad, then fabing up an adapter to bolt the new seat to your stock rail shouldnt be hard - just cant sell off your old seat without teh rails on them
removing the rails of the stock r33 is alot harder then you originally would figure I was looking to do it once and the problem was the rail is hooked up to the back seat adjuster and all that and also seatbelt buckles are part of it, if your gona do it either fabricate brackets from scratch or buy some ones reusing stock ones is to much effort
^^ yup there isnt really a way to reuse the rails from the 33 seats.
I used universal rails and made up some brackets out of steel to weld to either end of the rails. i made the brackets to be the same as the standard ones as far as looks. they just had to sit further out on the universal rails.was like $70 each rail set from autobarn and the a bit of scrap metal some time and a welder.
Also check the height of the back of the chair and check against yours as i had dramas with my autotechnica seats hitting the roof when brung forward to allow a passenger into the rear :blink:
So i sold em..
But the brackets worked a treat :banana:
Corey
Edited by sIIgtst
I thought Powerplay were the only people selling these
http://www.powerplayimports.com/index.php?...p;higher_cat=29
Nengun - ~ $860 each delivered
http://www.nengun.com/east-bear/sigma-reclining-seats
also appears C-Red have them
Wonder how much from powerplay??
You have to admit sometimes they are not the cheapest dealers around :D
Thanks for the links craved.
The freight is the killer:( but at leat there brand new instead of 2nd hand gtr ones - i will keep them in mind if i cant find a cheap set of 33gtr seats.
cheers rich
if you didnt want to keep your stock seats they would be usable as a rail for your new seats - just need to make a small frame to connect the seat to the stock 4 bolt setup - should be able tor etain the stock plastic side pieces
really depends on the seat you replace them with
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
